DIM REGISTER declares a global variable that lives in a register. This is generally a niche thing to do. The normal way to declare local variables is with just plain DIM or with VAR. The only difference is that VAR requires you to initialize the variable, and infers the type of the variable from the type of the expression. That is inside a function
VAR x = "hello"
is equivalent to
DIM x AS STRING
x = "hello"
Outside of any functions they are slightly different, with VAR declaring a variable that's not accessible to subroutines and functions (i.e. that's "local" to the PROGRAM statements).
I switched from a bunch of globals to VARs and the speedup was shocking
What had me confused was that I got the impression that; whatever the VAR is initialized with, establishes its type.
For example:
Var a = 1
A ubyte would suffice but I actually need a signed 32bit integer. Well, I actually do end-up with what I need so I guess that what the text really means is that:
For example:
Var a = 1
Var a = "1"
Establishes the variable as a string
Byte and word operations are slower and take up the same number of registers as long, so all integer expressions are treated as 32 bits for purposes of VAR. But there are more types than just string and integer, e.g.:
VAR a = 1 ' a is an integer
VAR a = 1.0 ' a is a single
VAR a = [x : => x+1] ' a is a function
VAR a = b ' makes a have the same type as b, *whatever* that is
DIMor withVAR. The only difference is thatVARrequires you to initialize the variable, and infers the type of the variable from the type of the expression. That is inside a functionis equivalent to
Thanks @ersmith Eric.
For example:
Craig
Ah, this I already expected to be the case but rather than appear lazy, was going to test.
Thanks again.
Craig
