PropTool binary files
ozpropdev
                                  in Propeller 2
        Hi All.
Recently i went back to an old P2 project which includes some PASM binary "blobs".
After generating some new binaries and dropping them into my code things broke.
After some detective work i discovered that the binaey is preceeded with an extra 16 longs of code.
Here's a disassembly of the code.
0000: FD601A00 HUBSET $D 0004: FD60181F WAITX $C 0008: FD601C00 HUBSET $E 000C: F607F040 MOV PTRA,#$40 0010: F607F200 MOV PTRB,#$0 0014: FCD8080F REP #$4,$F 0018: FD67FE29 SETQ2 #$1FF 001C: FB040161 RDLONG $0,PTRA++ 0020: FD67FE29 SETQ2 #$1FF 0024: FC6401E1 WRLONG $0,PTRB++ 0028: 00000000 NOP 002C: FCEC0000 COGINIT #$0,#$0 0030: 00030D40 _RET_ ROR $186,$140 0034: 01000708 _RET_ ADD $3,$108 0038: 0100070B _RET_ ADD $3,$10B 003C: 00000001 _RET_ ROR $0,$1
I'm assuming this is relates to Chip's debug option.
Anyhow just a heads up so others don't get caught out.
Oz
That code is the clock_setter.spin2 prefix introduced with PNut sometime ago (not sure when v36 or v37), should not do any harm.
See somewhere in the PNut discussion https://forums.parallax.com/discussion/171196/pnut-spin2-latest-version-v39-parameterization-bug-fixed-no-more-automatic-file-spewing
@macca
In my case it does a lot of harm.
It changes my clock settings, and shuffles hub ram then kills my already running cog #0.
Now i am aware of it, my custom loader strips it away.
Oz
The clocksetter only gets prepended when compiling an ASM-only file in non-debug mode. It really is quite silly.
I'd recommend just using flexspin for ASM projects. It doesn't do the clock setter thing and has some extra features I consider essential.
As a side note, with a bit of self-promotion, with my Spin Tools IDE the clock setter prefix is optional.
BTW Pnut supports DEBUG but does not include the clpck setter patch in its binary file.
That works for me.
