PROPOSAL: Disable DEBUG compilation per-object — Parallax Forums
We posting spin language proposals now?
There's already a number of DEBUG_ constants that can be defined to modify DEBUG behaviour.
Can we add one that disables compilation of debug statements on a per-object basis? Maybe DEBUG_DISABLE ? This way, debug code could be left in a library object without clogging up the main application's output. Especially relevant to the USB code, since in some cases there are timing issues caused by the DEBUG output.
So basically:
  • If the debugger is not enabled, no debug statements are built, full stop.
  • If the debugger is enabled and DEBUG_DISABLE is set in an object, debug statements in that object are not built.
  • If the debugger is enabled and the special constant is not set, build debug statements as normal.
@cgracey
@ersmith
  • evanhevanh Posts: 17,038
    I like it.
  • Seems like it should be straightforward to implement in flexspin (you could probably do it, but I'm happy to as well). Let's see what @cgracey and @macca think.
  • It would be handy, especially if you need to focus on just one thing at a time and you use other objects written with existing DEBUG statements in them.
    I have implemented it so it works also with object parameters:
    OBJ
    driver : "driver_object" | DEBUG_DISABLED=1
    Actually any value disable debug it just checks if defined.
  • Wuerfel_21Wuerfel_21 Posts: 5,765
    edited 2023-06-09 09:57
    Well that was the intent. Though I'd say it's slightly better to check for a non-zero value, so it can be disabled by default and then overriden to being enabled.
  • ersmithersmith Posts: 6,234
    edited 2023-06-10 15:06
    Should the constant be DEBUG_DISABLE (as in the original post) or DEBUG_DISABLED (as in the example @macca posted)? I lean towards the first, but obviously it's easy to do either way.
  • Oh, didn't even notice the discrepancy. Idk it doesn't matter.
    Ah... I hadn't noticed it either... :smile: doesn't matter to me, maybe DEBUG_DISABLE is more syntactically correct given the actual effect depends on the expression evaluation.
  • We all seem to slightly prefer DEBUG_DISABLE, so that it is.
    I consider this feature a blocker for non-beta release of the usbnew driver, btw (so you can debug your application without getting spammed with USB-related stuff or having to edit the driver file)
