A method to compare strings lexographically using inline assembly
Hello Everybody,
I wrote this inline P2 assembly code to sort strings lexographically. I wrote a small demo program using my siblings names, no Altaira was not one of my siblings, she was in one of my favorite movies "Forbidden Planet". The sort algorithm that I used is very inefficient but easy to program, a 'bubble sort'
HydraHacker
CON
_clkfreq = 180_000_000
numElemnts = 13
PUB main() | l, t, t1
debug("Unsorted list")
repeat l from 0 to numElemnts - 1
debug(zstr_(@@strsPtrTb[l]), dly(250))
debug(zstr_(string(" ")))
t:=getct()
bubbleSort()
t1:=getct()
debug("Sorted list")
printList()
debug(udec(t1-t-40))
repeat
PUB cmpStrs(str1adr, str2adr) : r | c
org
mov ptra, str1adr 'move str1adr into ptra
mov ptrb, str2adr 'move str2adr into ptrb
.l rdbyte r, ptra++ 'read str1 byte into r, then inc ptra
rdbyte c, ptrb++ 'read str2 byte into c, then inc ptrb
sub r, c wcz 'subtract c from r, set cz flags
if_z tjnz c, #.l 'if r = c and c <> 0 then jmp to .l
if_c mov r, ##-1 'if r < c then r = -1
if_nc_and_nz mov r, #1 'if r > c and r <> c then r = 1
end
'defines what r means upon method(s) exit
'if str1adr < str2adr then r = -1
'if str1adr > str2adr the r = 1
'if str1adr = str2adr then r = 0
PUB bubbleSort () | l, sf, t
repeat
sf := false 'swap flag = false
repeat l from 0 to numElemnts - 2 'loop through all elements minus two
if cmpStrs(@@strsPtrTb[l + 1], @@strsPtrTb[l]) == -1 'if strsPtrTb[index + 1] < strsPtrTb[index] then swap elements
t := strsPtrTb[l]
strsPtrTb[l] := strsPtrTb[l + 1]
strsPtrTb[l + 1] := t
sf := true 'swap flag set if two elements were swapped
while sf 'repeat loop if any swaps were made
PUB printList() | l
DAT
nme1 byte "Jeff", 0
nme2 byte "Dave", 0
nme3 byte "Brian", 0
nme4 byte "Kenny", 0
nme5 byte "Diane", 0
nme6 byte "pam", 0
nme7 byte "Jimmy", 0
nme8 byte "Debbie", 0
nme9 byte "Altaira", 0
nme10 byte 0
nme11 byte "Katherine", 0
nme12 byte "Jim", 0
nme13 byte 0
strsPtrTb word @nme1, @nme2, @nme3, @nme4, @nme5, @nme6, @nme7, @nme8, @nme9, @nme10, @nme11, @nme12 ,@nme13
Aaaa a bubble, it is evil, stop it before it is too late!
I once implemented (with some help) with a more efficient algorithm for sorting files in VentilatorOS.
PRI sortFiles(length) : i | ip,jp,i2p,zonep,k,realsize,subsize,sizze,temp[12/4] '' Sort the Files... if length < 2 ' no need to sort if < 2 entries return '' Non-recursive in-place sorting algorithm '' As relayed to me by a friendly Discord user '' (ported to spin and optimized by me) subsize := 12 length *= 12 repeat while subsize < length sizze := subsize<<1 repeat i from 0 to length-12 step sizze jp := (ip:=@sort+i)+subsize realsize := sizze <# (length-i) i2p := ip repeat k from 0 to realsize-12 step 12 if jp => (ip+realsize) or i2p => jp 'pass elseif compareNames(i2p,jp) =< 0 i2p += 12 else zonep := jp repeat if (zonep+12) == (ip+realsize) longmove(@temp, i2p,3) longmove(i2p,jp,3) longmove(jp,jp+12,(zonep-jp)>>2) longmove(zonep,@temp,3) if jp == zonep i2p += 12 else k -= 12 quit elseif compareNames(zonep+12,i2p) > 0 longmove(@temp, i2p,3) longmove(i2p,jp,3) longmove(jp,jp+12,(zonep-jp)>>2) longmove(zonep,@temp,3) if jp == zonep i2p += 12 else k -= 12 quit zonep += 12 subsize := sizzeThis as-is is obviously written for 12-character strings in an array, but it of course applies to any sort operation. Also, this is Spin 1, take care.
Also, you can make the string compare much faster by using the FIFO for one of the strings
PUB cmpStrs(str1adr, str2adr) : r | c org rdfast #0, str1adr mov ptrb, str2adr .l rfbyte r rdbyte c, ptrb++ sub r, c wcz if_z tjnz c, #.l if_nz sar r,#31 if_nz or r,#1 endWuerfel_21,
Thank you for speeding up my inline assembly with rdfast, I'll try that out later!
HydraHacker
If you can sacrifice an additional BYTE after the terminating 0, use that as an Index. So instead of moving the entire BYTE contents, just change the Index value to reflect the sort order.
Beau Schwabe,
Yes that would improve the speed, thanks for the suggestion.
HydraHacker
