Better build tasks config for VS Code
The tasks.json file recommended on the Parallax site works well, except one thing: each time you compile or download code, it opens a new terminal. It's not a big deal, but I just do not like that. So I made changes that make VS Code reuse same terminal panel, and the workspace looks a bit cleaner.
The list of changes:
"presentation"
sections:- changed
"panel": "new"
to"panel": "dedicated"
. This makes the task reuse its own terminal panel - changed
"focus": true
to"focus": false
. This way the editor does not lose focus when running a task - added
"showReuseMessage":false
. This removes the message from the terminal that is added when terminal is reused - added
"clear": true
. This clears the terminal output before running a task
- changed
changed task labels. I feel "Propeller: Compile Current File" looks better than "compileP2"
I also had to modify the custom key bindings file to use the new task labels.
I hope this can be useful
"version": "2.0.0",
"tasks": [
"label": "Propeller: Compile Current File",
"type": "shell",
"osx": {
"command": "flexspin.mac",
"windows": {
"command": "flexspin.exe",
"linux": {
"command": "flexspin",
"args": [
"-2",
"-Wabs-paths",
"-Wmax-errors=99",
"${fileBasename}"
"problemMatcher": {
"owner": "Spin2",
"fileLocation": ["autoDetect", "${workspaceFolder}/src"],
"pattern": {
"regexp": "^(.*):(\\d+):\\s+(warning|error):\\s+(.*)$",
"file": 1,
"line": 2,
"severity": 3,
"message": 4
"presentation": {
"panel": "dedicated",
"focus": false,
"showReuseMessage":false,
"clear": true
"group": {
"kind": "build",
"isDefault": true
"label": "Propeller: Compile Top File",
"type": "shell",
"osx": {
"windows": {
"linux": {
"args": [
"-2",
"-Wabs-paths",
"-Wmax-errors=99",
"${config:topLevel}.spin2"
"problemMatcher": {
"owner": "Spin2",
"fileLocation": ["autoDetect", "${workspaceFolder}"],
"pattern": {
"file": 1,
"line": 2,
"severity": 3,
"message": 4
"presentation": {
"focus": false,
"clear": true
"label": "Propeller: Download Code",
"type": "shell",
"args": [
"-b230400",
"${config:topLevel}.binary",
"-t"
"osx": {
"command": "loadp2.mac",
"windows": {
"command": "loadp2.exe",
"linux": {
"command": "loadp2",
"args": [
"-b230400",
"-t",
"-p/dev/ttyUSB0"
"problemMatcher": [],
"presentation": {
"focus": false,
"clear": true
"dependsOn": [
Hadden notice that. It always reuses the terminal window for me. I often have to kill it because my serial connection to the P2 is not broken.
Compiles always reuse the same terminal for me.
@"Andrey Demenev" Hmmm... thanks for figuring this out and posting. I'll test and then adjust my documentation and examples at my site.
-Stephen
@"Stephen Moraco"
Maybe that depends on VS Code version? @iseries says it worked differently
