Donkey Car
Does anyone here do Donkey Car?
If so I have some questions -
- Is it better to run a P2 or adapt something else to work?
- Can I still run my opto-isolaters and external 512k memory chips with the P2 if I am running a camera module?
- Does Parallax have any decent motor controllers or are they all limited to mostly low speed?
- How well does the P2 hook up to USB and IoT interfaces when it comes to external links for computing power?
- How well does the P2 and its accessories handle vibration and impact? Namely roll-over and the requried derby?
- How cold can the P2 be and still function? Some of what I want to do is outside in the winter and -30 or -40 is fairly common.
I don't do it but it looks amazing! I'm sure a P2 could do it, but according to that page:
Just because these cars are small and inexpensive doesn’t mean that you can’t run real autonomous car software on them. Like their big brothers, they run ML/CV software, from TensorFlow and OpenCV to ROS and Keras. To keep costs down, they split their computational tasks between Raspberry Pi or Jetson Nano computers onboard for real-time processing and cloud processing for offline training.
Are those two computers required?
I don't but it sure looks fun.
The P2 wouldn't be my first choice. If I were to enter, I'd use a P1 for the low level motor control with encoder feedback. I'd then use a Raspberry Pi or Jetson Nano for the machine vision. The P2 likely could do some pretty cool machine vision stuff but I think the previously mentioned options have a larger body of open source software available.
Yes to this but I'm not sure you really want to use a P2 for the machine vision (as previously mentioned).
Parallax has several motor controllers which would work fine with a variety of motors. If you use brushed motors, this dual MC33926 board would work. There are lots of other cheap h-bridge boards which would also work.
The P2 connects to USB just fine. I don't think it has intergrated IoT support but a WiFi module of some sort would be easy to add. I've used the ESP32 with a bunch of Propeller 1 and 2 projects. The ESP32 has WiFi and Bluetooth included.
I don't think this will be an issue. As long as you don't use the P2 as your bumper, it should be fine.
I don't think P2 is any more sensitive than other microcontrollers. Where do live to commonly get -40 degree weather?
As erco points out, the software suggested, doesn't directly run on the P2.
Again, as I mentioned above, I'd use a P1 as a helper chip for a Raspberry Pi or Jetson Nano. Parallax has had various robotic platforms which used a P1 connected to a host PC. Eddie and Arlo are a couple of examples of these sorts of platforms. I think both Eddie and Arlo used a PC running ROS. The host PC issued commands to the P1 board to drive motors.
The Open Propeller Project #8 converted existing Eddie code to run on the Propeller Activity Board. Here's a link to some of the work I did on this project.
The code used in that project could interface with a Raspberry Pi or Jetson Nano.
