PNut/Spin2 Latest Version (v51 - New POW, LOG2, EXP2, LOG10, EXP10, LOG, EXP floating-point ops) - Page 59 — Parallax Forums
1565759616275
  • Having them copied to cogRAM over and over isn't very efficient. I'd like a way to say call this pasm code as execute-in-place hubexec.
    Would it help to move your pasm code into the free interpreter space with setregs?
  • evanhevanh Posts: 16,394
    Huh, SETREGS() makes REGLOAD() completely redundant. Yeah, that can work but is quite space limited. Also, without any built-in allocation schemes to match, I'm not a fan of using any of those methods. And that goes for methods like LONGMOVE() too.
  • puta stub in there with SETREGS and call some HUBexec Code from there?
    edited 2022-12-20 10:21
    That still fails the non-allocated test. And just looks ugly!
    I guess, if we're going for ugly, I might experiment with making a temporary solution of dual compile paths so that Flexspin is also catered for. Conditional compiling is supposed to doable in Pnut now I think ... EDIT: or not. Eric posted a workaround solution - https://forums.parallax.com/discussion/comment/1543640/#Comment_1543640
    Ah, and I found this in Chip's Spin2 doc too. It's as ugly as SETREGS is but it should provide the execute in place I'm after.
    Hmm, except that example doesn't work with Pnut v37 ... I've now tried a couple Pnut releases from both v35 and v34, none work. They all report the same error of "Undefined symbol" on x
  • TonyB_TonyB_ Posts: 2,204
    edited 2022-12-20 18:14
    @evanh said:
    I'm not the wiser as yet. Was there an example removed?
    No. The inline routine in Spin2_interpreter.spin2 could be modified by anyone to not copy to cog RAM, in theory anyway.
    Incidentally, I notice that PNut_v37.zip has a file named instructions_future.txt with contents:
    MOVCMP  D,{#}S      'move and compare, useful for delta check and new-->old
    I'm still clueless sorry. I don't know anything about using XBYTE.
    edited 2022-12-21 04:00
    Evan, I'm not sure what you want done but here is the inline routine in Spin2_interpreter.spin2 (v37):
    ' a: In-line PASM
    ' b: REGEXEC(hubadr)
    ' c: REGLOAD(hubadr)
    ' d: CALL(anyadr)
    inline      setq    #16-1               'a          load local variables from hub into buff
                rdlong  buff,dbase          'a
                bith    pb,#31              'a          set flag to restore local variable to hub
                mov ptrb,pb                 'a          get bytecode ptr into ptrb
                skip    ##%11100100000111   'a  x2      begin inline_pasm skip pattern
    regexec_    skip    ##%1111000000       '| b    x2  begin REGEXEC skip pattern
    regload_    mov ptrb,x                  '| b c      get hubadr into ptrb
                rdword  w,ptrb++            'a b c      read start register
                rdword  y,ptrb++            'a b c      read length of pasm code, minus 1
                setq    y                   'a b c      read in code
                altd    w                   'a b c
                rdlong  0,ptrb++            'a b c      altd causes ptrb++ to inc by 4, not by (y+1)*4
        _ret_   popa    x                   '| | c      REGLOAD done, pop stack
                shl y,#2                    'a |        update bytecode ptr for inline_pasm
                add y,ptrb                  'a |
    call_       mov w,x                     '| |   d    get CALL address
                popa    x                   '| b   d    pop stack
                mov y,pb                    '| b   d    save bytecode ptr
                mov z,ptra                  'a b   d    save ptra
                call    w                   'a b   d    call pasm code (can use pa/pb/ptra/ptrb/stack, C/Z=0)
                mov pb,y            wc      'a b   d    restore bytecode ptr
        if_c    setq    #16-1               'a b   d    if inline_pasm, restore local variables to hub
        if_c    wrlong  buff,dbase          'a b   d
        _ret_   mov ptra,z                  'a b   d    restore ptra
    16 longs of variables are transferred to/from cog RAM before/after code is copied.
    Aside: could setd after rdword w,ptrb++ replace the altd that causes the ptrb++ bug?
    edited 2022-12-21 08:23
    What?! You replied to the very post with my example and request to Chip. I'm asking Chip to provide a Spin2 language mechanism for executing Pasm code directly in hubRAM without the need to copy it to cogRAM first. When a routine has no loops it gains no speed benefit from being run in cogRAM while still incurring the setup and copy overheads.
    PS: In short, Flexspin has this feature already and if Pnut/Proptool got it too then I'd make use of it all the time.
    Flexspin's language syntax is simple enough - ORG/END is for cogexec only, ASM/ENDASM is for optimiser to choose between hubexec and cogexec depending on what it thinks is best. If Pnut selected only hubexec for ASM/ENDASM then that'd be fine.
  • Chip's example code won't work because x is a hub variable not a cog register.
    VAR variables are all in hubRAM but aren't the first 16 or so locals in cogRAM?
    What you want done is very easy if starting from scratch. Even if code not copied from hub to cog RAM there will be 16 longs copied both ways. What does Flexspin do? I only use it for PASM.
    edited 2022-12-21 11:56
    Spin2 CALL works this way.
    I'm asking for a new feature from Pnut. What is starting from scratch?
    I just tried that above. It seems to be broken. Not sure if it ever was working to be honest.
    edited 2022-12-21 12:20
    Re altd bug, couldn't existing code
                altd    w                   'a b c
                add y,ptrb                  'a |
    be replaced with this?
                setd    patch               'a b c      *** new ***
    '           altd    w                               *** not needed ***
    patch       rdlong  0,ptrb++            'a b c      *** ptrb correct ***
    '           shl y,#2                                *** not needed ***
                mov y,ptrb                  '           *** changed ***
  • @evanh
    From the docs.
    • Methods can have up to 64KB of local variables, which can be bytes, words, and longs (default), in both singles and arrays._
    Try this
    pub go()
      repeat
        call(@random)
        pinwrite(56 addpins 1,PR0)
        waitms(100)
    dat     orgh
    random  getrnd wc
            _ret_  rcl PR0,#1
    @ozpropdev said:
    From the docs.
    Yeah, and the first 16 are in cogRAM.
            _ret_  rcl PR0,#1
    That's not going to happen - Copying to parameters, then to PRs, then back again - I was prepared to bend over for the ugliness but not for the double handling when avoiding that was the objective in the first place.
  • @evanh : Just to be clear: I think you're asking @cgracey to implement flexspin's inline ORGH feature, so that e.g.
    PUB sum(a, b) : r
      orgh
        add a, b
        mov r, a
      end
    would work just like the version with ORG, but instead of placing the inline assembly code in COG memory it goes into HUB memory and is executed directly from there. Does that sound right? (In flexspin terms ORGH/END is like ASM/ENDASM except the inline code isn't touched by the optimizer).
    PUB sum(a, b) : r
      orgh
        add a, b
        mov r, a
      end
    In flexspin are the variables copied from hub to cog RAM before calling the routine then copied back afterwards?
  • @TonyB_ said:
    PUB sum(a, b) : r
      orgh
        add a, b
        mov r, a
      end
    In flexspin the variables are always in cog RAM (at least by default).
    PUB sum(a, b) : r
      orgh
        add a, b
        mov r, a
      end
    Nice, yes, ideal for Chip to use that. Is ORGH/END inlining a new feature or have I just not seen it in the docs?
  • @evanh: ORGH / END has been in flexspin and documented since July (I think it was you who asked for hubexec without optimization in Spin2, wasn't it? The other languages already had it.)
    edited 2022-12-25 11:24
    I don't think it was me, I still do most testing in C.
    My Spin work is more on the Prop1 these days, I have a small paying job there - Hacked together a stepper driver and Modbus driver from the OBEX and customised them for a custom made PCB with eight tiny stepper motors attached to each board in a multi-drop RS485 network. The boards and motors are located in a rotary sealing head on a packaging machine. Two slip-rings for power and two for data.
    Each stepper driver manages a pair of motors. So four cogs used for them alone.
  • cgraceycgracey Posts: 14,277
    Sorry, I just noticed this thread. Haven't been to the forum in a week.
    I like Eric's ORGH/END approach.
    I will review all this tomorrow.
  • Unrelatedly, now that we have this spiffy constant override feature, can we get conditional assembly?
    i.e.
    DAT
    if SOME_CONSTANT == 1
        nop
    elseif SOME_CONSTANT == 2
        shl x,#1
    else
       mul x,#SOME_CONSTANT
    end
    I posted a new v38 at the top of this thread.
    • Bug fixed from v37 that didn't allow parent-object CON blocks to use CON symbols from child objects.
    • Bug fixed in interpreter which caused ROTXY/POLXY/XYPOL to not work.
    • REPEAT-var returned to original behavior where var = (final value +/- step) after REPEAT.
    • All DEBUG displays now use gamma-corrected alpha blending for anti-aliasing.
    FYI - I think the 2 BAT files need to be updated to reflect V38.
    Ah, thank you. I will fix that.
    edited 2023-03-05 12:39
    I posted a new v39 at the top of this thread.
    • Bug fixed from v37 that caused uniquely-parameterized child objects of the same file to all be the same.
    • No more ".obj" files generated automatically, as objects are now buffered in PC RAM to maintain uniqueness.
    • No more ".lst" list files generated automatically, now only via Ctrl-L or Ctrl-I.
    • No more ".txt" documentation files generated automatically, now only via Ctrl-D.
    • No more ".bin" binary files generated automatically, now toggled via Ctrl-R.
    • New hub checksum computation in the PASM debugger should improve change sensitivity.
    • Bug fixed from v38 that caused the REG/LUT/HUB maps to be too low-contrast in the PASM debugger.
    Note that I downloaded about three newer versions over the original file that I posted earlier tonight. I kept finding things that needed fixing.
    I posted a new version (40) at the top of this thread. It adds 'REPEAT count WITH variable' to simplify 0..n-1 loops.
    Here is the new zip file:
    https://drive.google.com/file/d/1ZgSfEjS3-qSZa82fd0xXUs7AnWBsAzjX/view?usp=sharing
