Code for a one Button RUN / STOP for the BS1
in BASIC Stamp
Hello,
I can't seem to figure this one out...
The push button switch is one active low normally open contact which closes when pushed. (P0=0)
My goal is to press the button once to RUN and the same button again to STOP. A flag bit (Bit 0) would change state with Run and STOP. Thanks, Jim
j.aaa8jr@gmail.com
Hi @Clovey
I don't have the hardware setup to try, but would something like this work for you ?
' BUTTON.BS2 ' Connect an active-low circuit to pin P0 of the BS2. When you press the ' button, the DEBUG screen will display an asterisk (*). The program, as ' shown below, will print an asterisk at the first button press, then ' delay approximately one second (200 x 5 ms PAUSE) before auto-repeating ' at a rate of approximately 100 ms (5 x 20 ms). Feel free to modify the ' program to see the effects of your changes on the way BUTTON responds. ' {$STAMP BS2} ' {$PBASIC 2.5} Btn PIN 0 btnWrk VAR Byte btnLastState VAR Byte btnLastState = 0 Main: ' Try changing the Delay value (255) in BUTTON to see the effect of ' its modes: 0 = no delay; 1-254 = varying delays before auto-repeat; ' 255 = no auto-repeat (only one action per button press) ' ' The BUTTON instruction will cause the program to branch to ' No_Press unless P0 = 0 PAUSE 5 BUTTON Btn, 0, 200, 20, btnWrk, 0, No_Press IF btnLastState = 1 THEN btnLastState = 0 DEBUG "RUN" ELSE btnLastState = 1 DEBUG "STOP" ENDIF No_Press: GOTO MainI used to write a hundred or so BS1 programs every year around Halloween for people using the EFX-TEK Prop-1 controller (has nothing to do with the Propeller 1 which was released after the BS1-powered Prop-1). To do what you want reliably, you'll want a debounce and force the button to be released. You could do it in a subroutine like this:
Check_Button: timer = 0 CB_Now: IF Trigger = NotPressed THEN CB_Exit PAUSE 5 timer = timer + 5 IF timer < 50 THEN CB_Now CB_Release: IF Trigger = Pressed THEN CB_Release ' force release PAUSE 100 ' let button clear state = state ^ 1 ' flip state CB_Exit: RETURNThis ensures a good button press and then allows a clean release. In the main body of your code you could do something like this.
The attached listing compiles, but I did not connect to a BS1.
