Propeller Midi Player (alpha) XmasMusic8a
in Propeller 1
Hi All
I am trying to run the object code will others .midi files but it didn´t Works.
It is same convertion to be made in other .midi files (Happy Birthday to You.midi , for exemple).
Thank you.
Masselon
I do ask:
There is same convertion to be made in other .midi files (Happy Birthday to You.midi , for exemple)?
Can u provide link to where this code came from ?
Hi Rayman
That is the link:
https://www.rayslogic.com/propeller/Programming/WavetableMidi/WavetableMidi.htm
Thought that looked familiar ...
That was from 2008 though... Not sure I remember much about it.
I think this note is important though: Only works with level-0 Midi files, a basic type with only one track.
Don't remember now how I created a level-0 midi file... I'll look around to see if I can find what made them...
I found a thread with what might be a better midi player:
https://forums.parallax.com/discussion/111867/music-synthesizer-object-with-general-midi-sound-set
Also mentions some software that can convert midi to level-0
