FM module
in Accessories
Does anyonr remember when parallax carried an FM module? If so where can I get some. I know parallax doesn't carry them any more but I'd like to know where to get some. Thank you
Hi @4x5n
Are you talking about these:
https://forums.parallax.com/discussion/131976/fm-receiver-module-documentation
Hope it helps
Henrique
P.S. in case of a positive answer about the FM Receiver chip, found another reference (full datasheef in english):
https://datasheet.lcsc.com/szlcsc/RDA5807M_C82537.pdf
That board uses that chip. I'm looking for the board.
I have one of the 27984 FM RadioReceiver modules with its documentation and P1 Quickstart software examples.
The module was from Parallax around 2011 and is no longer available.
I've attached a zip file with all the information/files I have about the module.
Unfortunately there isn't any PCB design information included, but the board is very simple and could be reversed engineered to have new boards designed/made.
You can also find other boards that probably would work just as well:
https://www.amazon.com/Stereo-Module-RDA5807M-Wireless-RRD-102V2-0/dp/B0B82P2TZ4
https://www.ebay.com/itm/224102559402
Thanks I think the board you pointed out will do what I want. I'm sure it'll come with info on how to hook it up. Thanks
