01f64 | ' PUB setWindow(xs, ys, xe, ye)
01f64 | _LCD_Graphics_Driver_setWindow
01f64077204 F6 | mov COUNT_, #701f683C 00 A0 FD | call #pushregs_
01f6c7A 0001 F6 | mov local01, arg0101f707B 0201 F6 | mov local02, arg0201f747C 0401 F6 | mov local03, arg0301f787D 0601 F6 | mov local04, arg0401f7c | ' ' Set Screen Window (column start, row start, column end, row end)
01f7c | ' curx:= xs
01f7c24 B404 F1 | add objptr, #3601f805A 0061 FC | wrlong local01, objptr
01f8424 B484 F1 | sub objptr, #3601f88 | ' cury:= ys
01f8828 B404 F1 | add objptr, #4001f8c5A 0261 FC | wrlong local02, objptr
01f9028 B484 F1 | sub objptr, #4001f94 | ' WaitMailbox()
01f9498 FE BF FD | call #_LCD_Graphics_Driver_WaitMailbox
01f98 | ' mailbox2s:= (xs<<16) | ys ' xs, ys
01f98800801 F6 | mov local05, local0101f9c100865 F0 | shl local05, #1601fa0810841 F5 | or local05, local0201fa408 B604 F1 | add ptr__LCD_Graphics_Driver_dat__, #801fa85B 0861 FC | wrlong local05, ptr__LCD_Graphics_Driver_dat__
01fac08 B684 F1 | sub ptr__LCD_Graphics_Driver_dat__, #801fb0 | ' mailbox2e:= (xe<<16) | ye ' xe, ye
01fb0820801 F6 | mov local05, local0301fb4100865 F0 | shl local05, #1601fb8830841 F5 | or local05, local0401fbc0C B604 F1 | add ptr__LCD_Graphics_Driver_dat__, #1201fc05B 0861 FC | wrlong local05, ptr__LCD_Graphics_Driver_dat__
01fc40C B684 F1 | sub ptr__LCD_Graphics_Driver_dat__, #1201fc8 | ' mailbox4 := (xe - xs +1)*(ye - ys +1) ' calc no. of pixels
01fc8820801 F6 | mov local05, local0301fcc800881 F1 | sub local05, local0101fd0010805 F1 | add local05, #101fd4830A 01 F6 | mov local06, local0401fd8810A 81 F1 | sub local06, local0201fdc010A 05 F1 | add local06, #101fe0850801 FD | qmul local05, local0601fe4180C 61 FD | getqx local0701fe814 B604 F1 | add ptr__LCD_Graphics_Driver_dat__, #2001fec5B 0C 61 FC | wrlong local07, ptr__LCD_Graphics_Driver_dat__
01ff014 B684 F1 | sub ptr__LCD_Graphics_Driver_dat__, #2001ff4 | ' mailbox := $81_00_000001ff4008040 FF
01ff8000805 F6 | mov local05, ##-213070643201ffc5B 0861 FC | wrlong local05, ptr__LCD_Graphics_Driver_dat__
020003B F003 F6 | mov ptra, fp
020044600 A0 FD | call #popregs_
02008 | _LCD_Graphics_Driver_setWindow_ret
020082D 0064 FD | ret
However with -O1 all the calculations are skipped:
01f64 | ' PUB {++opt(1)} setWindow(xs, ys, xe, ye)
01f64 | ' ' Set Screen Window (column start, row start, column end, row end)
01f64 | ' curx:= xs
01f6424 B404 F1 | add objptr, #3601f685A F460 FC | wrlong arg01, objptr
01f6c | ' cury:= ys
01f6c04 B404 F1 | add objptr, #401f705A F660 FC | wrlong arg02, objptr
01f7428 B484 F1 | sub objptr, #4001f78 | ' WaitMailbox()
01f78 B4 FE BF FD | call #_LCD_Graphics_Driver_WaitMailbox
01f7c7A F880 F1 | sub arg03, arg0101f8001 F804 F1 | add arg03, #101f847B FA 80 F1 | sub arg04, arg0201f8801 FA 04 F1 | add arg04, #101f8c7D F800 FD | qmul arg03, arg0401f90 | ' mailbox2s:= (xs<<16) | ys ' xs, ys
01f9010 F464 F0 | shl arg01, #1601f947B F440 F5 | or arg01, arg0201f9808 B604 F1 | add ptr__LCD_Graphics_Driver_dat__, #801f9c5B F460 FC | wrlong arg01, ptr__LCD_Graphics_Driver_dat__
01fa0 | ' mailbox2e:= (xe<<16) | ye ' xe, ye
01fa004 B604 F1 | add ptr__LCD_Graphics_Driver_dat__, #401fa45B F460 FC | wrlong arg01, ptr__LCD_Graphics_Driver_dat__
01fa8 | ' mailbox4 := (xe - xs +1)*(ye - ys +1) ' calc no. of pixels
01fa808 B604 F1 | add ptr__LCD_Graphics_Driver_dat__, #801fac | ' mailbox := $81_00_000001fac18 FA 60 FD | getqx arg0401fb05B FA 60 FC | wrlong arg04, ptr__LCD_Graphics_Driver_dat__
01fb414 B684 F1 | sub ptr__LCD_Graphics_Driver_dat__, #2001fb80080 C0 FF
01fbc5B 0068 FC | wrlong ##-2130706432, ptr__LCD_Graphics_Driver_dat__
01fc0 | _LCD_Graphics_Driver_setWindow_ret
01fc02D 0064 FD | ret
I think FlexSpin detects that the mailbox2s/2e and mailbox4 variables are never used (by the Spin code) and therefore thinks the calculations can be optimized away. However, the PASM part of the code relies on the results! I hope I don't have to mark them as "volatile" or something.
The only calculation that's missing is the one for mailbox2e, which it apparently decides can be the same as mailbox2s. Try -O1,~cordic-reorder or -O1,~local-reuse, it's likely one of those having a normal one.
Yes, you're correct, the same value is stored int mailbox2e as in mailbox2s which explains why it works for single pixel units. But the calculation of mailbox4 (no. of pixels) is totally skipped.
You mean as temporary workaround? If the mailbox variables were local then I'd agree that the compiler could optimize away calculations of which the result is nerver used. But writing to a DAT section should clearly signal "hey, this data might be used somewhere else, don't optimize away!".
Anyway, replacing an expression mailbox2e:= (xe<<16) | ye with a different one mailbox2e:= (xs<<16) | ys is definitely a compiler bug and can't be explained with "too much optimization". It's simply wrong. Or am I missing something?
Ok, next problem. I can't find anything in the docs about how DEBUG is supported. It seems to work in Spin, e.g. if I put something like debug ("paintIcon", udec(bg), udec(fg)) into the assembler part in the DAT section inside the Spin2 code and switch on "BRK debug (P2 only)" in the options menu of FlexProp I can see the debug output in the terminal window.
But if I try the same in the assembler part inside a C file then I get error messages like "unexpected '(' in line..." after the "debug" statement. I think PASM sections should be treated the same no matter if they are in a Spin or C file, shouldn't they.
Where do you see it skipped? It just moves it up due to the pipeline delay on the multiply (or, more accurately, stuff from above and below is pulled into the gap between QMUL/GETQX):
01f7c 7A F8 80 F1 | sub arg03, arg01
01f80 01 F8 04 F1 | add arg03, #1
01f84 7B FA 80 F1 | sub arg04, arg02
01f88 01 FA 04 F1 | add arg04, #1
01f8c 7D F8 00 FD | qmul arg03, arg04
[other stuff here]
01fac 18 FA 60 FD | getqx arg04
01fb0 5B FA 60 FC | wrlong arg04, ptr__LCD_Graphics_Driver_dat__
To figure out which optflag is buggy. Alternatively, post a complete sample that we can try locally (doesn't have to actually do anything, just enough to get the buggy codegen to show up)
Yes, that is indeed wrong. Are you using the very latest version, btw? I think a bug kinda like that was fixed recently.
Uhh! I didn't look carefully enough. I just saw that a lot of code is missing between the wrlong to mailbox2e and wrlong to mailbox4. I haven't noticed that the code has moved upward.
@Wuerfel_21 said:
... Try -O1,~cordic-reorder or -O1,~local-reuse, it's likely one of those having a normal one.
I've extracted a reduced version that can show the bug but doesn't output anything. It's not as short as it could be. I simply crippled the assembler code so that it doesn't output anything to the pins but instead signals completion through the mailbox immediately. Compile the demo and search the listing file for "PUB setWindow(".
Okay, -O1,~cordic-reorder does infact bypass the issue. Hmm. Though no idea how a bad reorder would lead it to believe that the second expression can be removed and replaced with the result of the second. My money is on "other bug that only happens in the state that the reorder creates"
Edit: Or maybe not, both expressions pass through the same temporary, so if the second expression disappears, they are actually the same
Okay, so here's what's going on: here's the code of intereset, as compiled with -O1,~cordic-reorder,~local-reuse. Read bottom to top (as the block find algorithm goes):
@evanh said:
I've managed to save one case - full source code attached - of weird behaviour by making a backup of it at that time. It's a different problem I think but one that has cropped up in completely different code before ... In the DAT section below, if I swap the two lines io_delay long 1 and prblob long 0[4] with each other then I get a repeating-print crash. Otherwise it runs fine.
DAT
prblob long0[4]
io_delay long1
txdata byte0[BLOCKSIZE]
rxdata byte0[BLOCKSIZE]
PS: The crash occurs at the first block copying to/from the PSRAM. After it has reset and ID queried each chip.
PPS: And a little debug shows it is during the transmit routine. So it's the first attempt to block write from the buffers. But not the first use of either io_delay or prblob.
I can't actually run the code right now (I'm away from my P2), but I see that io_delay is used in some calculations that use multiplies, so it's possible this bug may be the one that Ada just fixed where sometimes pulling calculations into CORDIC delay slots didn't check dependencies correctly.
DEBUG() is a Spin2 feature, so it's not available (yet) in C.
As to how to treat PASM sections in other languages... that's a big headache. The definition of PASM is tied up with the definition of Spin2 in unfortunate ways. This makes things like for example how to evaluate expressions very complicated; do we use the native language order of evaluation, or the Spin2 one? I've tried to work around this to some degree in C by having different keywords (__asm and __pasm) but this is still not a complete solution.
Ok, I understand. So the __pasm{} sections are not parsed by the same parser as the DAT sections are for Spin2 code? Surprises me but I do not know all details of the implementation.
Is there a way to get around this limitation? I could declare the assembler code in a spin2 file, export the entry point address and use that in C code.
Easier debugging saves a lot of time. Especially cog memory is not accessible from the outside and you can't just put a printf there.
Yes, unfortunately the whole C file is parsed by the C parser and so the __pasm syntax is hacked in. Adding DEBUG for it is on my todo list, but I don't know when it will happen.
Yes, that's exactly what I would do. You can have the assembler code in a file that's imported into C via struct using.
I had to get rid of 64bit integer constants first in "1LL" format, but this was no problem (replacing with a float)
Then I tried to add main() and call some functions from it. All my trial to call mp3_decode() ends with this:
"/home/pik33/Programy/flexprop/bin/flexspin" -2 -l --tabs=8 -D_BAUD=230400 -O1 --charset=utf8 -I "/home/pik33/Programy/flexprop/include""/home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3.c"
Propeller Spin/PASM Compiler 'FlexSpin' (c) 2011-2022 Total Spectrum Software Inc.
Version 5.9.13-beta-HEAD-v5.9.12-3-ge286147b Compiled on: Jun 212022
child killed: segmentation violation
Finished at Mon Aug 111:49:152022
either in Linux or in Windows (official 5.9.14)
Version 5.9.15-beta-HEAD-v5.9.14-9-g03841438 Compiled on: Aug 1 2022also gives a segmentation fault
Pik's post reminded me to test this ... No change. Still doing the repeat print crashing with latest build of master. Version 5.9.15-beta-v5.9.14-9-g03841438 Compiled on: Aug 1 2022
@pik33 said:
I tried to compile and use this minimp3 decoder.
Replacing with a float will probably lose precision. As of 5.9.14 the 1LL format constants should be supported now. Did you find some that aren't?
Are you sure you posted the version that you were compiling? In both Linux and Windows I did not get any segmentation fault when compiling minimp3.c. I did get some errors about missing 64 bit arithmetic functions; I've fixed those and checked in the fix to github. Now it complains about a missing main(), which seems to be correct.
Does it still happen with optimization turned off? How about in bytecode mode (-2nu)?
It heavily relies on Fcache to place the inline Pasm in cogRAM, so I kind of need the optimiser. Or is there a way to specify where the Pasm is placed irrespective of optimiser setting?
As for -2nu, I get this error: psram16_batty_crashing.spin2:122: error: identifier getrnd not found
EDIT: Replaced the randfill() function with the newer pasm version and got that compiling with -2nu ... but no joy with the critical part, it crashes at the same place I think ... err, no, the repeat print crashing is much earlier, at the init_smartpins() function .. which is the first piece of inline pasm.
That's why I added a simple main() to this. It compiles until the main tries to call mp3_decode().
Or if I add this to the Basic as a class, the result is the same. I can call mp3_create( ), but not mp3_decode()
The first try was official 5.9.14 in Windows. Then I moved to Linux and used this 5.9.13. The last try was to recompile a new 5.9.15. All of these version give the same result: call mp3decode() and the compiler does segmentation fault.
I will recompile the compiler and try the newest version.
Recompiled.
Version 5.9.15-beta-HEAD-v5.9.14-11-g2f5736d1 Compiled on: Aug 2 2022
Now 1LL works, but calling mp3_decode() still generates a segfault. I will try to debug this by commenting out...
I now managed to compile a first test, replacing these FIXHR with precomputed constant integers.
Something seems to work.... Time to try, connect the audio output to the decoder...
Why the pointer returned by calloc in mp3_create is 6382bb88?
Minimp3 is too slow for a P2... One mp3 block, 26 ms of audio, is decoded in 121/113 (with -O2) ms at 337 MHz - 5x too slow to use.
Also, looking through the macros, I think MULS is only used for 16x16 multiplication, so you can reimplement it as such (normal multiply operator only ever generates QMUL/GETQX)
All this MULS/MULH stuff has to be rewritten which I already tried with MULH (asm with qmul, which worked but it did nothing for the speed). It not only gets time, but I don't know why they decided to work in 15:17 format. It generates noise - I have this minimp3 compiled for Ultibo - and the noise is easy hearable in silent parts of music. I ended with libmad on Ultibo. It is also integer based, but they use 4:28 fixed point and it is silent (enough), Maybe try, compile libmad if I can...
I have also mp2 decoder in C, this is simpler so I may try this too
There's also libtremor lowmem branch for integer-only ogg vorbis. I tried compiling that at some point, but the 64 bit support (and general C compliance) just wasn't there yet.
Semi-relatedly, if the format is of no matter, I've been experimenting for a while to conjure up a decent ADPCM-based music compression scheme with P1 in mind (though I haven't actually developed a non-PC/C++ decoder). I'm on like the 4th rewrite of that and it doesn't totally suck now (i.e. to the point where the quantization noise is low enough that it isn't distracting). But that's at some ~240kbps (slightly less than 60 512 byte SD sectors per second) for 32kHz stereo so perhaps not efficient enough for whatever you want to do.
You can turn off the optimizer and turn on just fcache with a command line option of something like -O0 --fcache=128.
I don't have the hardware to test this, and I also seem to have an older stdlib.spin2 that's missing some functions you're using, so I can't even compile it . But things to try:
(1) As a sanity check: does this exact code work correctly in PNut / PropTool?
(2) Does the inline pasm depend on any hard coded registers? It doesn't look like it but it's worth double checking.
(3) I don't see any printing in the init_smartpins() function. What exactly is getting stuck printing? What's it printing? Is it possible that it's stuck in some kind of reset loop?
Hmm, the optimizer seems to be "too smart" and optimizes away important parts of the code. This is the source:
PUB {++opt(1)} setWindow(xs, ys, xe, ye) ' Set Screen Window (column start, row start, column end, row end) curx:= xs cury:= ys WaitMailbox() mailbox2s:= (xs<<16) | ys ' xs, ys mailbox2e:= (xe<<16) | ye ' xe, ye mailbox4 := (xe - xs +1)*(ye - ys +1) ' calc no. of pixels mailbox := $81_00_0000
With optimization off this is compiled correctly:
01f64 | ' PUB setWindow(xs, ys, xe, ye) 01f64 | _LCD_Graphics_Driver_setWindow 01f64 07 72 04 F6 | mov COUNT_, #7 01f68 3C 00 A0 FD | call #pushregs_ 01f6c 7A 00 01 F6 | mov local01, arg01 01f70 7B 02 01 F6 | mov local02, arg02 01f74 7C 04 01 F6 | mov local03, arg03 01f78 7D 06 01 F6 | mov local04, arg04 01f7c | ' ' Set Screen Window (column start, row start, column end, row end) 01f7c | ' curx:= xs 01f7c 24 B4 04 F1 | add objptr, #36 01f80 5A 00 61 FC | wrlong local01, objptr 01f84 24 B4 84 F1 | sub objptr, #36 01f88 | ' cury:= ys 01f88 28 B4 04 F1 | add objptr, #40 01f8c 5A 02 61 FC | wrlong local02, objptr 01f90 28 B4 84 F1 | sub objptr, #40 01f94 | ' WaitMailbox() 01f94 98 FE BF FD | call #_LCD_Graphics_Driver_WaitMailbox 01f98 | ' mailbox2s:= (xs<<16) | ys ' xs, ys 01f98 80 08 01 F6 | mov local05, local01 01f9c 10 08 65 F0 | shl local05, #16 01fa0 81 08 41 F5 | or local05, local02 01fa4 08 B6 04 F1 | add ptr__LCD_Graphics_Driver_dat__, #8 01fa8 5B 08 61 FC | wrlong local05, ptr__LCD_Graphics_Driver_dat__ 01fac 08 B6 84 F1 | sub ptr__LCD_Graphics_Driver_dat__, #8 01fb0 | ' mailbox2e:= (xe<<16) | ye ' xe, ye 01fb0 82 08 01 F6 | mov local05, local03 01fb4 10 08 65 F0 | shl local05, #16 01fb8 83 08 41 F5 | or local05, local04 01fbc 0C B6 04 F1 | add ptr__LCD_Graphics_Driver_dat__, #12 01fc0 5B 08 61 FC | wrlong local05, ptr__LCD_Graphics_Driver_dat__ 01fc4 0C B6 84 F1 | sub ptr__LCD_Graphics_Driver_dat__, #12 01fc8 | ' mailbox4 := (xe - xs +1)*(ye - ys +1) ' calc no. of pixels 01fc8 82 08 01 F6 | mov local05, local03 01fcc 80 08 81 F1 | sub local05, local01 01fd0 01 08 05 F1 | add local05, #1 01fd4 83 0A 01 F6 | mov local06, local04 01fd8 81 0A 81 F1 | sub local06, local02 01fdc 01 0A 05 F1 | add local06, #1 01fe0 85 08 01 FD | qmul local05, local06 01fe4 18 0C 61 FD | getqx local07 01fe8 14 B6 04 F1 | add ptr__LCD_Graphics_Driver_dat__, #20 01fec 5B 0C 61 FC | wrlong local07, ptr__LCD_Graphics_Driver_dat__ 01ff0 14 B6 84 F1 | sub ptr__LCD_Graphics_Driver_dat__, #20 01ff4 | ' mailbox := $81_00_0000 01ff4 00 80 40 FF 01ff8 00 08 05 F6 | mov local05, ##-2130706432 01ffc 5B 08 61 FC | wrlong local05, ptr__LCD_Graphics_Driver_dat__ 02000 3B F0 03 F6 | mov ptra, fp 02004 46 00 A0 FD | call #popregs_ 02008 | _LCD_Graphics_Driver_setWindow_ret 02008 2D 00 64 FD | ret
01f64 | ' PUB {++opt(1)} setWindow(xs, ys, xe, ye) 01f64 | _LCD_Graphics_Driver_setWindow 01f64 | ' ' Set Screen Window (column start, row start, column end, row end) 01f64 | ' curx:= xs 01f64 24 B4 04 F1 | add objptr, #36 01f68 5A F4 60 FC | wrlong arg01, objptr 01f6c | ' cury:= ys 01f6c 04 B4 04 F1 | add objptr, #4 01f70 5A F6 60 FC | wrlong arg02, objptr 01f74 28 B4 84 F1 | sub objptr, #40 01f78 | ' WaitMailbox() 01f78 B4 FE BF FD | call #_LCD_Graphics_Driver_WaitMailbox 01f7c 7A F8 80 F1 | sub arg03, arg01 01f80 01 F8 04 F1 | add arg03, #1 01f84 7B FA 80 F1 | sub arg04, arg02 01f88 01 FA 04 F1 | add arg04, #1 01f8c 7D F8 00 FD | qmul arg03, arg04 01f90 | ' mailbox2s:= (xs<<16) | ys ' xs, ys 01f90 10 F4 64 F0 | shl arg01, #16 01f94 7B F4 40 F5 | or arg01, arg02 01f98 08 B6 04 F1 | add ptr__LCD_Graphics_Driver_dat__, #8 01f9c 5B F4 60 FC | wrlong arg01, ptr__LCD_Graphics_Driver_dat__ 01fa0 | ' mailbox2e:= (xe<<16) | ye ' xe, ye 01fa0 04 B6 04 F1 | add ptr__LCD_Graphics_Driver_dat__, #4 01fa4 5B F4 60 FC | wrlong arg01, ptr__LCD_Graphics_Driver_dat__ 01fa8 | ' mailbox4 := (xe - xs +1)*(ye - ys +1) ' calc no. of pixels 01fa8 08 B6 04 F1 | add ptr__LCD_Graphics_Driver_dat__, #8 01fac | ' mailbox := $81_00_0000 01fac 18 FA 60 FD | getqx arg04 01fb0 5B FA 60 FC | wrlong arg04, ptr__LCD_Graphics_Driver_dat__ 01fb4 14 B6 84 F1 | sub ptr__LCD_Graphics_Driver_dat__, #20 01fb8 00 80 C0 FF 01fbc 5B 00 68 FC | wrlong ##-2130706432, ptr__LCD_Graphics_Driver_dat__ 01fc0 | _LCD_Graphics_Driver_setWindow_ret 01fc0 2D 00 64 FD | ret
mailbox2e
, which it apparently decides can be the same asmailbox2s
. Try-O1,~cordic-reorder
or-O1,~local-reuse
, it's likely one of those having a normal one.Yes, you're correct, the same value is stored int mailbox2e as in mailbox2s which explains why it works for single pixel units. But the calculation of mailbox4 (no. of pixels) is totally skipped.
with a different onemailbox2e:= (xs<<16) | ys
is definitely a compiler bug and can't be explained with "too much optimization". It's simply wrong. Or am I missing something?Ok, next problem. I can't find anything in the docs about how DEBUG is supported. It seems to work in Spin, e.g. if I put something like
into the assembler part in the DAT section inside the Spin2 code and switch on "BRK debug (P2 only)" in the options menu of FlexProp I can see the debug output in the terminal window.But if I try the same in the assembler part inside a C file then I get error messages like "unexpected '(' in line..." after the "debug" statement. I think PASM sections should be treated the same no matter if they are in a Spin or C file, shouldn't they.
01f7c 7A F8 80 F1 | sub arg03, arg01 01f80 01 F8 04 F1 | add arg03, #1 01f84 7B FA 80 F1 | sub arg04, arg02 01f88 01 FA 04 F1 | add arg04, #1 01f8c 7D F8 00 FD | qmul arg03, arg04 [other stuff here] 01fac 18 FA 60 FD | getqx arg04 01fb0 5B FA 60 FC | wrlong arg04, ptr__LCD_Graphics_Driver_dat__
Okay,
-O1,~cordic-reorder
does infact bypass the issue. Hmm. Though no idea how a bad reorder would lead it to believe that the second expression can be removed and replaced with the result of the second. My money is on "other bug that only happens in the state that the reorder creates"Edit: Or maybe not, both expressions pass through the same temporary, so if the second expression disappears, they are actually the same
. Read bottom to top (as the block find algorithm goes):mov local02, arg01 ' \ shl local02, #16 ' | or local02, arg02 ' | IT REORDERS THIS BLOCK WTF add ptr__LCD_Opt_Driver_dat__, #8 ' | wrlong local02, ptr__LCD_Opt_Driver_dat__ ' / mov local02, arg03 ' \ shl local02, #16 ' / Can't reorder because dependency or local02, arg04 ' Can't reorder due to arg4 use add ptr__LCD_Opt_Driver_dat__, #4 ' Can reorder wrlong local02, ptr__LCD_Opt_Driver_dat__ ' Can reorder sub arg03, arg01 ' \ add arg03, #1 ' | QMUL dependencies, can't reorder sub arg04, arg02 ' | add arg04, #1 ' / qmul arg03, arg04 getqx local03
Thus after a reordering pass we get:
mov local02, arg03 shl local02, #16 or local02, arg04 sub arg03, arg01 add arg03, #1 sub arg04, arg02 add arg04, #1 qmul arg03, arg04 mov local02, arg01 shl local02, #16 or local02, arg02 add ptr__LCD_Opt_Driver_dat__, #8 wrlong local02, ptr__LCD_Opt_Driver_dat__ add ptr__LCD_Opt_Driver_dat__, #4 wrlong local02, ptr__LCD_Opt_Driver_dat__ getqx local03
Which is obviously very wrong. After a dead code removal pass:
... we end up with the garbage we get.
Aaaand fix submitted: Fix incorrect reorder when code being reordered over sets a non-dead value that would be clobbered
Wow, that was fast, thank you.
(check your inbox for reward)
"/home/pik33/Programy/flexprop/bin/flexspin" -2 -l --tabs=8 -D_BAUD=230400 -O1 --charset=utf8 -I "/home/pik33/Programy/flexprop/include" "/home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3.c" Propeller Spin/PASM Compiler 'FlexSpin' (c) 2011-2022 Total Spectrum Software Inc. Version 5.9.13-beta-HEAD-v5.9.12-3-ge286147b Compiled on: Jun 21 2022 child killed: segmentation violation Finished at Mon Aug 1 11:49:15 2022
Version
also gives a segmentation faultPik's post reminded me to test this ... No change. Still doing the repeat print crashing with latest build of master.
Is there a way to split a long p2asm source code line over two or more lines?
As inline Pasm within a C function, yep, the backslash of ordinary C formatting works.
Recompiled.
I commented out static int mp3_decode_frame() leaving only header and return - no segfault, but
/home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:802: error: global initializers are evaluated at compile time and therefore must be constant /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:802: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:802: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:803: error: global initializers are evaluated at compile time and therefore must be constant /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:803: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:803: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:804: error: global initializers are evaluated at compile time and therefore must be constant /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:804: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:804: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:805: error: global initializers are evaluated at compile time and therefore must be constant /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:805: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:805: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:806: error: global initializers are evaluated at compile time and therefore must be constant /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:806: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:806: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:807: error: global initializers are evaluated at compile time and therefore must be constant /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:807: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:807: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:808: error: global initializers are evaluated at compile time and therefore must be constant /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:808: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:808: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:809: error: global initializers are evaluated at compile time and therefore must be constant /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:809: error: Bad constant expression /home/pik33/Programowanie/P2-retromachine/Propeller/P2P16/minimp3/minimp3.c:809: error: Bad constant expression
These are
static const int icos36h[9] = { FIXHR(0.50190991877167369479/2), //--> line 802 FIXHR(0.51763809020504152469/2), //0 FIXHR(0.55168895948124587824/2), FIXHR(0.61038729438072803416/2), FIXHR(0.70710678118654752439/2), //1 FIXHR(0.87172339781054900991/2), FIXHR(1.18310079157624925896/4), FIXHR(1.93185165257813657349/4), //2 // FIXHR(5.73685662283492756461), };
How much I hate preprocesor programming
abuse.... They are f* constants, so they can be declared as constants instead....
This line: (1635)
buf[ + j] = MULH(t0, win[18 + j]);
caused a segfault.
Correcting this to
buf[ 0 + j] = MULH(t0, win[18 + j]);
makes segfault disappear
What is left, the compiler doesn't like these constants at 802-809, but at least it doesn't crash.
Looking at the code, you haven't redefined MULL/MULH, which causes it to go through a slow path, probably. Would need to look at disassembly...
static inline int32_t MULS(int16_t a, int16_t b) { int32_t tmp = a; __asm { muls tmp,b } return tmp; }
-O0 --fcache=128
.I don't have the hardware to test this, and I also seem to have an older stdlib.spin2 that's missing some functions you're using, so I can't even compile it
