Prop Proto Board schematic needed
kurth
in Propeller 1
Does anybody have the schematic for the Prop Proto Board (32212)? I can't find it on the Parallax site. Thanks!
Coudn't find it Parallax website either; resorted to Mouser UK and they have the following schematic:
mouser.co.uk/datasheet/2/321/parallax_32212-propeller-proto-schematic-reva-1197302.pdf
I don't know if it's the most recently available one nor if there was more than one version ever, so it's up to you to check.
Hope it helps...
Henrique
Excavating a bit more, now at the "old" Parallax Website:
https://www1.parallax.com/downloads/propeller-proto-board-schematic
https://www1.parallax.com/downloads/propeller-protoboard-documentation
"Tap Tap Tap"... just dust-covered...
Thanks Yanomani!
You're welcome, @kurth !
