Memory stick datalogger & basic stamp 2P problems.
Hello.
I got Basic Stamp 2P24 module, Stamps in class board and bought memory stick datalogger from parallax. Connected them as in datasheet, and downloaded the sample code.
So far, tried two low capacity flash drives, 1GB and 4GB. With both, symptoms are the same, I'm getting the following output:
Memory Stick Datalogger Test V1.1
Synchronizing...
Checking for USB Flash drive...
Drive
Ready...
Random Number (Seed) = 7618
Error reading the seed file -- Halting execution!
I've double checked the code and wiring, everything is OK. The power is also OK - I'm using AC power supply.
Synchronizing...
Drive
However, why there's no sample SIMPLE code, which will look like:
To read file from flash disk, use this code, to write file to flash disk, use this code and so on.
Why there's only one example, and complicated one? from the first look, it creates expression that it is necessary to use random seed to work with adapter.
And almost 10 years passed
Demo code seems to be gone from Parallax website
but I still have these laying around.
Any place where I can download it?
Try the archive site : https://www1.parallax.com/search?search_api_views_fulltext=memory+stick+datalogger
Thanks, but it seems like there's nothing to download regarding the statements needed to control this device.....
Found this, but it not that good: https://www.ftdichip.com/Firmware/Precompiled/UM_VinculumFirmware_V205.pdf
I use this one with my FTDI Vdrive3, works with no problem
I've used the vDrive extensively with the Stamp for weather data logging in long term remote deployments. I always include means to cycle the power. The vDrive has no other way to give a hard reset, and it can and does occasionally get locked up either through firmware errors or through bumps in the night. Also, for infrequent logging, turning off the power prolongs the battery life. I'll attach a test program, a terminal that allows the user to type in vDrive short commands and see the responses to commands like file and disk info and to experiment with opening and reading files.
Note that the baud constant for the BS2p is different from the BS2pe in the demo. Use $F0 (240 decimal) instead of $54 (84 decimal) as the baud constant.
I'll also attach my driver for the vDrive that occupies its own program slot on a BS2pe. It allows writing data records to a file, for reading back the file, and housekeeping chores. It is quite specific to my multi-slot programming templates, and is sub-slot, not a main program. but it might give you some ideas about how to proceed.
