can the BRK instruction be conditionalized?
ersmith
I've had reports of weird behavior of DEBUG statements in flexprop, and digging into it the offending DEBUGs all seem to have conditional BRK statements. That is,
if_e brk #2
doesn't work properly: it seems to always be triggered, but with an incorrect or corrupted immediate value. However,
if_ne jmp #L_tmp
brk #2
L_tmp
does work as expected.
@cgracey is there something in the hardware, or perhaps in the debug stub, that would not like conditional BRK?
[deleted]
That is peculiar behaviour ... but I do see it is documented in the silicon doc:
Can't think why Chip did it that way though.
Quoting what I said on GitHub:
Oh, I guess that improves pipeline reload times, especially in cogexec.
EDIT: Hmm, not sure it'll help speed wise given debug code is always hubexec. [scratches head]
@ersmith , would you want to make the assembler emit a warning when it sees a conditional on a
brkinstruction?Yes, that's a good idea. I've checked in that change.
