HUB RAM interface question - Page 5 — Parallax Forums
1235789
  • evanhevanh Posts: 17,140
    Yup. I believe this is something Chip now needs to add to his list of improvements if there is any silicon respins.
  • TonyB_TonyB_ Posts: 2,272
    edited 2022-02-20 15:35
    deleted
    I got that fitting after the bug fix:
     BYTE    3   55555556    78640    78648    98304    78640    98296    98304    78640    98296    78640    78648    0
    SHORT    3   55555556   589776    98320   589792    98304   589816    98312   589808    98312   589776    98320    0
     LONG    3   55555556   196624   196640   196616   196632   196632   196624   196624   196624   196624   196640    0
    C (number of cogs) = 8
    D (effective divisor) = 6 (BYTE), 3 (SHORT), 1.5 (LONG)
    Tu (Unimpeded Ticks) = 65536
    Tm (Measured Ticks) = 78640, 98304, 196624, 589792
    Te (Extra ticks) = Tm - Tu  =>  78640 - 65536 = 13104,  98304 - 65536 = 32768,  196624 - 65536 = 131088
    S (Stalls) = Te / C         =>  13104 / 8 = 1638     ,  32768 / 8 = 4096     ,  131088 / 8 = 16386
    Lb (FIFO burst length in longwords) = (C / D) * Tm / Te  =>  Lb = (C / D) * Tm / (Tm - Tu)  =>  Lb = C / (D * (1 - Tu/Tm))
    Lbb = 8 / (6 * (1 - 65536 / 78640)) = 8
    Lbs = 8 / (3 * (1 - 65536 / 98304)) = 8
    Lbl = 8 / (1.5 * (1 - 65536 / 196624)) = 8
    Lbb = 8 / (6 * (1 - 65536 / 98304)) = 4
    Lbs = 8 / (3 * (1 - 65536 / 589792)) = 3
    Lbl = 8 / (1.5 * (1 - 65536 / 589824)) = 6
    deleted
    edited 2022-02-20 13:59
    It gives right answers. I think that's because every multiple of eight is counted as a stall no matter how many contiguous rotations in a burst.
    edited 2022-02-20 15:34
    deleted
    edited 2022-02-20 14:51
    Mine is 8 right there. Well, 8 for FIFO acting normal and 6 for FIFO misbehaving.
    And we know it isn't always behaving well.
    edited 2022-02-20 15:00
    deleted
    @TonyB_ said:
    Streamer freq = sysclk/1.5 !!!
    Correct. It can handle it.
    I need a rethink.
    edited 2022-02-20 15:12
    Evan, your table here is confusing me:
    https://forums.parallax.com/discussion/comment/1535803/#Comment_1535803
    If numbers in second column are D as in sysclk/D, then they should be halved. Do you agree?
    edited 2022-02-20 15:26
    You can derive the effective divisor from it easy enough but it's not directly the divisor. It's an index that is used for calculating the NCO value that goes to SETXFRQ. It doesn't changed for the three lines because neither does the XFRQ change.
    EDIT: I should point out this is all about FIFO/hubRAM bandwidth, not streamer rate. So the "effective divisor" is with respect to the cog's hubRAM bandwidth.
    Is $5555_5556 the actual D value you use for SETXFRQ D for long streaming?
    edited 2022-02-20 15:27
    Yes. Each test line in the report has it's own.
    Thank you. Concurrent fast move and FIFO performance is amazing, except for the 'glitches'.
    edited 2022-02-20 15:44
    It's cool alright. The advantages of buffering and bursting. FIFO is doing two jobs in effect. Shows off the enormous bandwidth of hubRAM too. Not too surprising it can impact power consumption.
    edited 2022-08-29 22:15
    Apologies if I said you were wrong when you weren't. I think that examining sysclk/1.5 for longs could tell us quite a lot about how FIFO works.
    No worries, I was staying open to a proof. Things changed a lot at my end along the way. I had been fixing lots of other parts before that final bug with the duplicated streamer mode. So, up until then I was still struggling to fit it all together.
  • The excessive timings could be explained mathematically by either increasing revs per stall or decreasing burst length. The latter seems more likely in reality.
    edited 2022-02-20 16:11
    Here's a case where SHORT won't to drop to 1 longword per burst. The divider means only LONG triggers it.
     BYTE   18   0e38e38e    68064    68056    68056    68056    68064    68056    68064    68056    68064    68056    0
    SHORT   18   0e38e38e    70784    70776    70784    70776    70784    70776    70776    70776    70784    70776    0
     LONG   18   0e38e38e    76928    76936    76936   589680   589752   589824   589824   589536    76928    76936    0
    D (effective divisor) = 36 (BYTE), 18 (SHORT), 9 (LONG)
    Tm (Measured Ticks) = 68056, 70776, 76936, 589824
    Te (Extra ticks) = Tm - Tu  =>  68056 - 65536 = 2520,  70776 - 65536 = 5240,  76936 - 65536 = 11400
    S (Stalls) = Te / C         =>  2520 / 8 = 315      ,  5240 / 8 = 655      ,  11400 / 8 = 1425          65536
    Lbb = 8 / (36 * (1 - 65536 / 68056)) = 6
    Lbs = 8 / (18 * (1 - 65536 / 70776)) = 6
    Lbl = 8 / (9 * (1 - 65536 / 76936)) = 6
    Lbl = 8 / (9 * (1 - 65536 / 589824)) = 1
    edited 2022-02-20 16:47
    Good work Evan, showing that burst length can be as low as one during bus hogging.
    I think this is the way sysclk/1.5 for longs works:
    < Rev0 >< Rev1 >< Rev2 >    egg beater Revolutions
    012345670123456701234567    hub RAM slices
    WWWWWWWW................    fast block Write
    ........IIIIIIIIIIIIIIII    FIFO In
    OO.OO.OO.OO.OO.OO.OO.OO.    FIFO Out
    122344565554443332221110    FIFO unfilled longs
    Yikes, unwanted bolding makes it hard to read.
    FIFO has maximum of 6 unfilled longs.
    Yeah, looks good. And that's the non-hogging case. Okay, the hogging case must look atrocious.
    Is there any hogging in this instance?
    LOL. I had an almost identical diagram I started on this yesterday before abandoning it. This is what we need to have for the good vs bad case. I wanted to see the gaps where neither "W" or "I" would be present in the output, showing wasted HUB bandwidth. I wonder if a simple simulation stepping through the different addresses and modeling the FIFO depth triggering the "I" cycles while tracking the slice # could generate these.
    edited 2022-02-20 22:55
    Here is my first attempt at sysclk/9 for longs, fast and slow. In reality the fast one must use FIFO burst = 6 but I've shown it using burst = 8 because it was easier. The slow timing matches the equation with burst = 1 and that is what I've shown. The bottom line maybe should have 1's and 0's instead of 8's and 7's to indicate that the FIFO is being refilled when there is only one long free, for some reason. Comments welcome.
    < Rev0 >< Rev1 >< Rev2 >< Rev3 >< Rev4 >< Rev5 >< Rev6 >< Rev7 >< Rev8 >    egg beater Revolutions
    012345670123456701234567012345670123456701234567012345670123456701234567    hub RAM slices
    WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW........    fast block Write
    ................................................................IIIIIIII    FIFO In
    O........O........O........O........O........O........O........O........    FIFO Out
    111111111222222222333333333444444444555555555666666666777777777876543210    FIFO unfilled longs
    ........................................................WWWWWWWW........    fast block Write
    .I........I........I........I........I........I........I........I.......    FIFO In
    877777777877777777877777777877777777877777777877777777877777777877777777    FIFO unfilled longs
    Sure is, Lbl = 8 / (1.5 * (1 - 65536 / 589824)) = 6
    https://forums.parallax.com/discussion/comment/1535824/#Comment_1535824
    edited 2022-02-20 22:48
    Ah, cool, hubRAM fetches spaced same 9 tick interval as streamer cycles. EDIT: Okay, not cool outcome, knocks the cog back every time.
    Evan, I think that is sysclk/3 for longs and burst = 3. The line with 1966xx is consistent and applies to sysclk/1.5 for longs.
    edited 2022-02-20 22:54
    Actually, what it will be is:
    W........W........W........W........W........W........W........W........    fast block Write
    Visualising really helps!
    Oh, I see that data, 589824, is actually missing in newest runs. It has existed in previous runs of same config. I'm not yet sure how best to trigger worst case conditions.
