Console Emulation - Page 14 — Parallax Forums
Console Emulation
1111214161775
  • So here's the version with HDMI support (only changed file is MegaVGA.spin2. The VSync pin field is repurposed when using HDMI mode: if it is odd, the TMDS pins are reversed. If you use the HDMI accessory, you don't want this. Just set VSync pin to zero). Currently only a 800x480 mode is defined. If you want to do a different mode, keep in mind that you can not touch the vertical timing and that you should keep the system clock around that 326 MHz sweet spot.
    Will look into the regressions tomorrow. Also found that the worm at the beginning of Mega Turrican is invisible now for some reason. Rather strange.
    Not sure what would be worse: bug in the HyperRAM implementation or bug in the previous fixes.
  • Also, @Electrodude , here's that github: https://github.com/IRQsome/MegaYume
  • @Wuerfel_21 said:
    Not really. The problem is selecting between different implementations for memory access, which I'd solve with an #ifdef, but proptool doesn't do it, so what I do instead is:
      Enabled code
      Disabled code
    Along with labeling them all, that makes it not entirely infuriating to manage.
    I think the solution here is to just pester Chip and/or Jeff more.
    Agree. As someone who wants to support both platforms with my driver code without resorting to extreme methods like total duplication of files it would be nice to have some way to do this. Flexspin can use all the handy #if stuff and #include but PropTool cannot so if you try to use it you'll break PropTool. If we could even just have PropTool to recognize its own CON constants as a way to conditionally include/exclude some of the following lines being parsed, that at least would be a start. I know it quickly gets messy if there are multiple files or people then ask for nesting etc, but ideally we need something better than manually enabling/disabling various line groups all throughout the source files.
  • Agreed, having even a very basic preprocessor would be nice in PropTool. Having said that, there are a few work-arounds:
    The ternary operator ? works in CON sections for both FlexProp and PropTool, so there's a little bit of configuration possible via that e.g.:
    CON
       USE_PSRAM = 1
       PIN = USE_PSRAM ? 48 : 32
    And of course plain IF statements in PUB/PRI can be used to disable code (although probably PropTool doesn't do dead code elimination yet, so you do get code bloat :( ).
    With the most recent FlexSpin (still in github) you can test which compiler you're using via something like:
    PUB main()
    {$flexprop
       ' this stuff looks like code to FlexSpin
       ' but a comment to PNut / PropTool
       DEBUG("hello from FlexSpin", 13)
       ' now start a PNut only section via #ifndef
    #ifndef __FLEXSPIN__
       ' this is only in PNut/PropTool
       ' due to the #ifndef in the $flexprop comment above
       DEBUG("hello from PNut", 13)
    {$flexprop
    ' end the PNut only section
    #endif
  • Not exactly easy to read but at least it's something... :smile:
  • Figured out what the issue with Sonic 1 was. Apparently there's a bit of a non-bug where it tries to decompress level data from $0503BCF2. Real 68000 ingores the 8 unused bits at the top, but I was sending those out as part of the external RAM address. It seems the PSRAM chips have no problem with that, but the HyperRAM seems to return some sort of garbage.
    Mega Turrican is also fixed by this.
  • evanhevanh Posts: 16,697
    That was definitely poor coding practises by such programmers back then. Sadly it was all too common. The 68k logical address space was always 32-bit, even if a particular model of processor didn't fully implement it.
  • The other decompression calls (for the SEGA logo, title screen, etc) are on more sensible addresses, so I guess it's really just an oversight.
    Mind that they had this funny contraption called an "Address Checker" to make sure the games don't access invalid memory locations (beyond the ones that hang the machine due to missing DTACK)
    But those top address bits aren't brought out, so they couldn't check those.
  • Much of it is intentional. Writes to ROM. Use of mirrored memory addresses. Size checks.
    It was always a cat and mouse game, but if you can make a warehouse full of unauthorized hardware unsellable, you've at least won the current battle.
    Yeah, there's a bunch of tricks done with backup RAM in particular. That will surely be fun.
    Though that's got nothing to do with the 68000's 24 bit address bus.
    Current objective: Add 6-button controller support.
    Engineered to be crappy. So everyone ends up losing in the end.
  • Ok, 6-button support is in. I guess megayume is now Street Fighter 2 compliant ;P
    Some games (particularly early/unlicensed ones) break with this, so there's a config constant to choose what kind of pad is emulated.
  • I just realized that there's a Bad Apple for Megadrive, which I guess means there is now a Bad Apple for P2, sortof. I remember @pik33 asked for that ;P
    Alternate image title: I hate what the P2EVAL does to my desk.
    Staying on subject, you may also play this IPS patch I found at one point while browsing romhacking.net, wherein someone imported Reimu's sprites from Scarlet Weather Rhapsody into Streets of Rage 2, which I find incredibly funny for some reason. Artstyle clash ahoy!
  • Wuerfel_21Wuerfel_21 Posts: 5,534
    edited 2022-02-17 21:34
    Time for another ZIP:
    - Mask top bits of address on code read (fixes Vectorman on HyperRAM)
    - Fix CMP instructions setting X (they shouldn't. Doesn't seem to fix any perceived issue)
    - Increase VDP color ramp accuracy by precomputing shadowed/highlit colors
  • And here's another one that's been missing so far: Being able to hot-reset the emulator without reloading it.
    Well, it's a thing now, CTRL+R
  • Megayume alpha 032:
    • Improved YM2612 DAC distortion (applies even when muted via pan register)
    • Fix multiple issues wrt. VDP column scrolling
  • Taking advantage of the fact that MegaYume as a whole has a minimum clock frequency of around ~310 MHz whereas OPN2Cog was designed for 250 MHz, I've increased envelope generator update rate 6x (no more clicky attacks) and PSG sample rate 3x (less aliasing).
    Going to also post a standalone OPN2Cog with those modifications (as well as the distortion thing from yesterday) in the relevant thread soon, too.
  • In unrelated news, despite having other things to do, the thought of a SNES sound board emulator won't leave my head, so, uhh, I guess I kinda wrote an SPC700 CPU core. It runs some contrived test code, but is likely super buggy still. As expected, the entire CPU fits into memory with loads of wiggle room (LUT mostly used, COG mostly free).
  • @Wuerfel_21 said:
    … so, uhh, I guess I kinda wrote an SPC700 CPU core…
    You are just amazing.
    I get up in the morning and I think “I need to do laundry”.
    You get up and write a whole new machine… finish it… and I’m still doing laundry. 🤣
    edited 2022-03-01 21:12
    News on the SNES sound board front: Trying to work out how the S-DSP works and how to efficiently implement it. Nothing to show for it yet, just prototyping bits and pieces.
    In other words, welcome to my hell.
                  '' Update echo
                  ' Advance echo history
                  mov dsp_ehist+0,dsp_ehist+1
                  mov dsp_ehist+1,dsp_ehist+2
                  mov dsp_ehist+2,dsp_ehist+3
                  mov dsp_ehist+3,dsp_ehist+4
                  mov dsp_ehist+4,dsp_ehist+5
                  mov dsp_ehist+5,dsp_ehist+6
                  mov dsp_ehist+6,dsp_ehist+7
                  ' Read echo data into history
                  mov ptrb,dsp_eptr
                  add ptrb,sp_rambase
                  rdlong dsp_ehist+7,ptrb
                  testb dsp_ehist+7,#15 wc
                  bitc dsp_ehist+7,#16
                  sar dsp_ehist+7,#1
                  ' Advance pointer
                  add dsp_eptr,#4
                  zerox dsp_eptr,#15
                  cmp dsp_eptr,dsp_ewrap wz
                  ' Reset pointer if end reached
            if_z  getbyte dsp_eptr,dsp_dir_esa_edl,#1
            if_z  shl dsp_eptr,#8
            if_z  getnib dsp_ewrap,dsp_dir_esa_edl,#4
            if_z  shl dsp_ewrap,#11
            if_z  fge dsp_ewrap,#4
            if_z  add dsp_ewrap,dsp_eptr
                  zerox dsp_ewrap,#15
                  ' run FIR filter
                  scas dsp_efir+0,dsp_ehist+0
                  mov dsp_tmp1,0-0
                  getword pa,dsp_ehist+0,#1
                  scas dsp_efir+0,pa
                  mov dsp_tmp2,0-0
                  scas dsp_efir+1,dsp_ehist+1
                  add dsp_tmp1,0-0
                  getword pa,dsp_ehist+1,#1
                  scas dsp_efir+1,pa
                  add dsp_tmp2,0-0
                  scas dsp_efir+2,dsp_ehist+2
                  add dsp_tmp1,0-0
                  getword pa,dsp_ehist+2,#1
                  scas dsp_efir+2,pa
                  add dsp_tmp2,0-0
                  scas dsp_efir+3,dsp_ehist+3
                  add dsp_tmp1,0-0
                  getword pa,dsp_ehist+3,#1
                  scas dsp_efir+3,pa
                  add dsp_tmp2,0-0
                  scas dsp_efir+4,dsp_ehist+4
                  add dsp_tmp1,0-0
                  getword pa,dsp_ehist+4,#1
                  scas dsp_efir+4,pa
                  add dsp_tmp2,0-0
                  scas dsp_efir+5,dsp_ehist+5
                  add dsp_tmp1,0-0
                  getword pa,dsp_ehist+5,#1
                  scas dsp_efir+5,pa
                  add dsp_tmp2,0-0
                  scas dsp_efir+6,dsp_ehist+6
                  add dsp_tmp1,0-0
                  getword pa,dsp_ehist+6,#1
                  scas dsp_efir+6,pa
                  add dsp_tmp2,0-0
                  ' let taps 0..6 overflow
                  signx dsp_tmp1,#15
                  signx dsp_tmp2,#15
                  scas dsp_efir+7,dsp_ehist+7
                  add dsp_tmp1,0-0
                  getword pa,dsp_ehist+7,#1
                  scas dsp_efir+7,pa
                  add dsp_tmp2,0-0
                  ' saturate last add
                  fges dsp_tmp1,dsp_min
                  fges dsp_tmp2,dsp_min
                  fles dsp_tmp1,dsp_max
                  fles dsp_tmp2,dsp_max
                  '' TODO: add echo into main/feedback
                  '' write echo data
                  rolword dsp_recho,dsp_lecho,#0
                  testbn dsp_flg,#5 wc ' Echo write enabled?
            if_c  wrlong dsp_recho,ptrb ' ptrb is still pointing to echo buffer
  • Further update still: BRR decode, interpolation, mixing and echo seem to function now, but no luck getting it to run anything that isn't my contrived test code. Likely issue with CPU (or with loading the dump file). Timer could be borked, too, idk.
  • hinvhinv Posts: 1,256
    That is exactly the words I said out loud when reading her posts!
    No of course not, I am doing this on my Amiga that I don't have. ;P
    I'm really hoping that you had an Amiga early in life. If you got the bug to emulate an Amiga on the P2, that would be awesome! I'm also hoping someone will do a C64 Emulator, which would be quite a bit earlier, but somehow doesn't preform that well on a Raspberry Pi Zero...
  • pik33pik33 Posts: 2,414
    I hoped to try the emulator after attaching the 4-bit PSRAM to Eval, but not yet - 16 bit bus needed...
    I should be able to get that going, though IDK how performance will be. Just need to get the P2EDGE back on my desk (currently have EVAL+HyperRAM set up, because that, due to a curious shortage of USB to barrel cables, is also the setup I need to test HDMI (I'm too retro to have any actual proper HDMI monitors, I guess.))
    edited 2022-03-10 22:45
    In the meantime, here's a preview of the SNES sound thing (obviously titled SPCcog, because stealing @Ahle2 's brand, lol)
    Features:
    - can sometimes play some music
    Misfeatures:
    - clicky attacks on some instruments (I think I have an idea what is causing that)
    - some sort of memory corruption issue
    - hates Seiken Densetsu 3
    - was too lazy to edit out the LED debug stuff. Go find it yourself if you're not using a P2EVAL. Or don't, shouldn't matter if you aren't doing stuff with pins 56/57. Should be the only DRV* opcodes in the entire thing.
  • @pik33
    Here you go, ready for 4 bit PSRAM. Performance seems to be similar to HyperRAM.
  • That's cool if it still works ok with just the single PSRAM.
  • Yeah, it's neat. I think with reduced code que size it might go a bit faster still.
  • Yeah I guess if latency is still a major part, a single PSRAM with one quarter of the bandwidth isn't going to matter too much for small transfers. ie. Not a lot of difference between (a+b) and (a+4b) if a is bigger than b to begin with.
