+= works weird for strings — Parallax Forums
pik33pik33 Posts: 2,419
edited 2022-02-13 10:23 in BASIC (for Propeller)
dim filename$ as string
filename$="123456"
filename$+=space$(38)
print filename$
It compiles, but:
warning: assignment discards const attribute from pointer
and the result is: �x3��
Standard syntax works as expected: the result is 123456 and 38 spaces at the end.
filename$="123456"
filename$=filename$+space$(38)
print filename$
    filename$="123456"
    print filename$
    It compiles, but:
    filename$="123456"
    print filename$
    There were some bugs with handling the temporary strings required for += when the right hand side is a function call. For now either avoid += with strings (except for simple variables and literal strings) or else update to the most recent github source code.
    Thanks for the bug report,
