Nextion JonnyMac"s wk 3 HMI file clock not working pixels work flawlessly ?-Resolved — Parallax Forums
msiriwardenamsiriwardena Posts: 301
edited 2022-02-09 11:41 in Propeller 2
I have a nextion model#NX48332K035-011(enhance).
Loaded nextion with compiled TFT file (Wk-3). When I ran the HMI file the home page was loaded.
I Proseed to enter the date (HHMMSSD format) .
The date came up on the screen ans semi-colon was missing and the clock was not active.
When the pixel control was pressed the pixel control came up and the pixel control worked
flawlessly - all buttons and the sliders functioned well.
Hardware : jonnymac board (wire exactly to pixel controllers I/O pins). , RTC-ds3231, pixel string(50),nextion display as described earlier.
I would appreciate some help to resolve this issue.
Thank you,
siri
PS:The RTC is working tested with another time file.
The RTC in the nextion - in-active (no battery installed)
unable to upload a zip.picture file( too large).
Thank you again
siri
  • I resolved the issue myself it took a little while.
    The issue was I powered the nextion display as they
    suggested via the provided power connector with usb power connection to
    ensure adequate power to nextion display.
    I tried many times resetting the propeller and it did not work.
    Once I powered the nextion display via the jonnyMac board
    the nextion display worked as it was intended , the time was
    displayed and the pixels worked and re-setting the RTC worked.
    siri
  • You can use separate power supplies, but ground must be common between the P2 and the display. You did not mention separate power for the Nextion in your first post -- this is an important detail. Thankfully, you found it and fixed it. Have fun with the Nextion; they're really neat.
