problem I need help with
I wrote a simple program, just to play around with functions (subroutines) and the EEPROM memory stuff. Basically, it's supposed to ramp up to speed, drive forward, backwards, forwards, and then ramp down again. However, running the program, only the left wheel turns, not the right. I's not a hardware problem, because the wheel runs fine with other programs. Any help is appreciated. Here is my code:
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
pulsecount VAR Word
address VAR Byte
instruction VAR Byte
DATA "UFFBBFFD"
DO UNTIL (instruction = "Q")
READ address, instruction
address = address + 1
SELECT instruction
CASE "F": GOSUB forward
CASE "B": GOSUB backward
CASE "U": GOSUB ramp_up_forward
CASE "D": GOSUB ramp_down_forward
ENDSELECT
LOOP
END
forward:
FOR counter = 1 TO 25
PULSOUT 13, 800
PULSOUT 12, 700
PAUSE 20
NEXT
backward:
PULSOUT 13, 700
PULSOUT 12, 800
PAUSE 20
NEXT
ramp_up_forward:
FOR pulsecount = 1 TO 100
PULSOUT 13, 750 + pulsecount
PULSOUT 13, 750 - pulsecount
PAUSE 20
NEXT
ramp_up_backward:
PAUSE 20
NEXT
ramp_down_forward:
FOR pulsecount = 100 TO 1
PAUSE 20
NEXT
ramp_down_backward:
PAUSE 20
NEXT
The second PulseOut should be changed to PULSEOUT 12 to drive the other wheel.
well, that's a facepalm if I've ever seen one! I really should have seen that; thank you for your help! It works great now!
Good deal. Merry Christmas!
