uSD P2 FlexBASIC
I am trying to open a file, in a COG, and have something written there. But, in my program, nothing is happening. Not sure what I am missing.
Ray
' test2sd.bas
OPTION EXPLICIT '
CONST HEAPSIZE = 8192 ' lots of elbow room
mount ("/sd", _vfs_open_sdcardx(5,4,3,2)) ' mount the file system at /SD node
dim s$ as string
dim stack_dlog1(64)
dim cpuID_4 as long
cpuID_4 = cpu(dataLog(),@stack_dlog1(1))
do
pausems 2000
loop
end
'COGed datalog
sub datalog
open "/sd/dlog1.txt" for input as #8
print #8, "Datalog"
print "Debug, in datalog"
do
print #8, "a";chr$(13)
pausesec 1 ' Pause for five minutes.
loop
end sub
Only one COG at a time can use any set of pins, including the SD card pins. My recommendation would be to use the main COG for any file I/O, but if you really need to do file I/O in another COG (why??) then you'd have to do the mount in that COG as well.
What I was thinking about is testing the idea of, one COG would be collecting the data, and storing in a file, while another COG would be able to open the file, and do some sort of analysis of the data collected, if at all possible.
Ray
I am experimenting with the program below, and in a COG, the values that are being written are not what I am expecting.
Does this mean that when you mount in different COG, the uSD function works differently?
Ray
' test2sd.bas OPTION EXPLICIT ' CONST HEAPSIZE = 8192 ' lots of elbow room 'mount ("/sd", _vfs_open_sdcardx(5,4,3,2)) ' mount the file system at /SD node dim s$ as string dim stack_dlog1(64) dim cpuID_4 as long ' open "/sd/dlog1.txt" for output as #8 ' print #8, "Datalog" ' close #8 cpuID_4 = cpu(dataLog(),@stack_dlog1(1)) 'print "Debug, in datalog" dim a as integer do pausems 2000 ' open "/sd/dlog1.txt" for append as #8 ' print #8, a; ' print #8 chr$(13) ' a = a + 1 ' close #8 ' pausesec 1 ' Pause loop end 'COGed datalog sub datalog mount ("/sd", _vfs_open_sdcardx(5,4,3,2)) open "/sd/dlog1.txt" for output as #8 print #8, "Datalog" close #8 dim a as integer do 'pausems 2000 open "/sd/dlog1.txt" for append as #8 print #8, a; print #8 chr$(13) a = a + 1 close #8 pausesec 1 ' Pause loop end sub '''''''''''''''Don't mix this kind of operations between cogs. It can be a source of hard to find bugs.
Another question: can a channel number be 8? The FlexBasic help says this has to be 0 to 7, where 0 and 1 is reserved. Maybe this #8 is the source of the bug.
Edit: I found in the source code that max file# is 9, not 7
Now I know why. My main cog is doing SD "file manager" while another one wants to play .wav This is of course not possible with this architecture - now I need to write a "file access" cog driver with its own mailbox type API
Is there something like "unmount"?
