PropellerIDE needs to be updated ...
Phil Pilgrim (PhiPi)
... with the latest version of OpenSpin. (I was able to manually copy the latest .exe into the PropellerIDE folder, and it works.)
EXCEPT that OpenSpin doesn't load anything into the Prop chip under PropellerIDE. Can this be fixed, please? (So frustrating.)
And also, PropellerIDE doesn't handle extended ASCII in its terminal screen. Character $B0 (°) shows as a square block, rather than °. Oddly, the edit screen displays it properly.
