sndCogLut0 long sndCogLut0 whats up with this
in Propeller 2
The following code compiles . The Data declaration "sndCogLut0 long sndCogLut0" I would have thought the address value would be substituted but it something totally different. Using @sndCogLut0
does something different also. Whats' up?
Regards and Thanks
Bob (WRD)
CON
_clkfreq = 200_000_000 'system clock
CogNum = 1 'Cog to run
PUB main()
COGINIT(COGEXEC+CogNUM,@CogCode,@HubCode)
waitms(5000)
debug(udec(HubCode))
debug(udec(HubDataTable))
debug(udec(sndHubLut0))
repeat
DAT
ORG 0 'COG RAM
CogCode nop
debug(udec(CogCode))
debug(udec(CogDataTable))
debug(udec(sndCogLut0))
Loop0 nop
jmp #Loop0 'Jump to HubCode
CogDataTable long CogDataTable
DAT
ORGH 'HUB RAM
HubCode nop
Loop1 nop
jmp #Loop1
HubDataTable long HubCode '@HubCode start of HUBEXEC PASM
sndHubLut0 long sndHubLut0
yeah that is sort of a pitfall.
Spin Code is relocatable and all addresses are relative to some base pointers relative to the object containing the code.
And here comes the dilemma with @ @@ and @@@
At compiletime aka
myAdr LONG @whatever gives you the offset not the actual Hub Address.
At runtime
myAddr:= @whatever gives you the actual HUB address
BST invented @@@ to give you a HUB address at compile time so
myAdr LONG @@@whatever would give a Hub Address, but not supported by PropTool/Pnut, I think FlexProp does it.
I do not really remember what @@ was for, - Offset inside Object, something.
So getting hold of a absolute Hub Address is quite a challenge when using Spin.
Thanks for Reply. Who is BST?
Regards
Bob (WRD)
http://www.fnarfbargle.com/bst.html
Hello on the other side:
Starting with COGEXEC then HUBEXEC works for loading DAT initial values. But if you need to have the address of HUB values it gets messy. How do you get a second pointer address for using HUB RAM with RDLONG and WRLONG. The following is one way that seems to work but it wouldn't be relocatable as and object. The code requires calculating the HubCode address .
The code is reading HUB RAM variable to COG RAM variable then COG RAM variable LUT RAM then LUT RAM To COG RAM then COG RAM Back to HUB RAM(seems to work).
is there a better way for loading the HubCodeAddress then having to calculate it?
CON _clkfreq = 200_000_000 'system clock CogNum = 1 'Cog to run HubCodeAddress = 4_308 PUB main() debug("-------------------------") debug(udec(HubCode)) debug(udec(HubDataTable)) debug(udec(sndHubLut0)) debug(udec(sndHubLut1)) debug(udec(rcvHubLut0)) debug(udec(rcvHubLut1)) COGINIT(COGEXEC+CogNUM,@CogCode,@HubDataTable) 'To Determine @HubCode (HubCodeAddress) waitms(5000) 'replace use sndHubLut0 with @HubCode and replace debug("@HubCode= HubCodeAddress = 4_308") 'replace jmp ptrb with jmp #Loop0 to determine address @HubCode debug(udec(HubDataTable)) debug(udec(sndHubLut0)) debug(udec(sndHubLut1)) debug(udec(rcvHubLut0)) debug(udec(rcvHubLut1)) debug("-------------------------") repeat '------------------------------------------------------------------------------ DAT ORG 0 'COG RAM CogCode nop debug("-------------------------------") debug("Enter COGEXEC code") debug("HubDataTable Address= ",udec(ptra)) mov ptrb,##HubCodeAddress debug("HubCode= ",udec(ptrb)) mov CogDataTable,ptrb debug("@HubCode= ",udec(CogDataTable)) Loop0 nop jmp ptrb '#Loop0 'ptrb 'Jump to HubCode Use #Loop jmp to determine HubCodeAddress CogDataTable long 0 sndCogLut0 long 0 sndCogLut1 long 0 rcvCogLut0 long 0 rcvCogLut1 long 0 LutRamAddress long $200 'address of Look Up Table LUT RAM DAT ORGH 'HUB RAM HubCode nop debug("--------------------------------") debug("Enter HUBEXEC code") add ptra,#4 debug("sndHubLut0 Address= ",udec(ptra)) mov pa,LutRamAddress 'pa = address $200 rdlong sndCogLut0,ptra 'ptra = @sndHubLut0 0 => address sndCogLut0 wrlut sndCogLut0,pa 'pa = address $200 0 => address sndCogLut0 rdlut rcvCogLut0,pa 'pa = address $200 5 => address rcvCogLut0 debug("LUT RAM address $200 = ",udec(rcvCogLut0)) add ptra,#8 'ptra = rcvHubLut0 wrlong rcvCogLut0,ptra 'ptra = @rcvHubLut0 5=> @rcvCogLut0 debug(udec(sndCogLut0),udec(rcvCogLut0)) sub ptra,#8 'ptra = @sndHubLut0 add ptra,#4 'ptra = @sndHubLut1 add pa,#1 'pa = address $201 rdlong sndCogLut1,ptra 'ptra = @sndHubLut1 1 => address sndCogLut1 wrlut sndCogLut1,pa 'pa = address $201 1 => address sndCogLut1 rdlut rcvCogLut1,pa 'pa = address $201 6 => address rcvCogLut1 debug("LUT RAM address $201 = ",udec(rcvCogLut1)) add ptra,#8 'ptra = @rcvHubLut1 wrlong rcvCogLut1,ptra 'ptra = @rcvHubLut1 6 => address rcvCogLut1 debug(udec(sndCogLut1),udec(rcvCogLut1)) sub ptra,#12 'ptra = @SndHubLut0 sub ptra,#4 'ptra = @HubDataTable debug("HubDataTable= ",udec(ptra)) wrlong ptra,ptra debug("------------------------------") Loop1 nop jmp #Loop1 HubDataTable long 0 '@HubCode start of HUBEXEC PASM sndHubLut0 long 1111 sndHubLut1 long 2222 rcvHubLut0 long 0 rcvHubLut1 long 0 '------------------------------------------------------------------------------
Regards and Thanks
Bob (WRD)
If you use @Label in DAT sections, the hubaddress you get is relative to the object base address. You can get this baseaddress with @@0.
The following code passes this baseaddress in ptra, and has a (single instruction) subroutine to calculate the hubaddress from it.
_clkfreq = 20_000_000 PUB main() coginit(16, @cogcode, @@0) repeat DAT org 0 cogcode mov hubbase,ptra 'save hub baseaddr callpa #@hubcode,#hubadr 'calc absolute hubaddr into pa debug(uhex(pa)) jmp pa 'jump to hubcode hubadr _ret_ add pa,hubbase 'subroutine to calc hubaddr hubbase long 0 Delay long 10_000_000 Led long 60 hubcode drvnot Led waitx Delay callpa #@Const1,#hubadr 'get hubaddr of Const1 into pa rdlong pb,pa 'read Const1 value debug(uhex(pb)) jmp #hubcode Const1 long $1234
That would help in determining multiple address locations. I will try out tomorrow. That would then allow code to be relocatable as an object.
Thanks and Regards
Bob (WRD)
Used @@0 and obtaining hubBase address addiing this to the symbol offset value @hubCode gives absolute address of huBCode. Works as stated thanks.
Is there synopsis of how the Propeller Tool compiles program?
By this I mean how the Spin2 code is compiled creating object addresses and how DAT file gets stored. I would think this would contain the definition of @@0 .
What I have found in the documentation is:
Str0 BYTE "Monkeys",0 'strings with symbols Str1 BYTE "Gorillas",0 Str2 BYTE "Chimpanzees",0 Str3 BYTE "Humanzees",0 StrList WORD @Str0 'in Spin2, these are offsets of strings relative to start of object WORD @Str1 'in Spin2, @@StrList[i] will return address of Str0..Str3 for i = 0..3 WORD @Str2 'in PASM-only programs, these are absolute addresses of strings WORD @Str3 '(use of WORD supposes offsets/addresses are under 64KB) 'Note: Long can be used if address is greater than 64k suggest using Long always
The @ ins and the friends @@ and @@@ are usually a Spin-syntax but often used in DAT sections thus also valid for assembler.
So in the case of REP the @ has a complete different meaning. @ instructs the compiler to See how many instructions follow the REP instruction to the symbol pointed to with @Symbol.
Regards and Thanks
Bob (WRD)
