AUGD and WAITX Syntax question
I am trying to use WAITX in HUB Execute mode trying to point to "cntDelay" in the HUB memory using "AUGD #n" and "WAITX D" in COG Execute mode to have Dest_Register to be used. Below is code I have tried (have tried several different address qualifiers @,# forms with no Luck)
PS tried to use ~~ for indentation (didn't work)
'Using HUB Memory Execute
CON
_clkfreq = 200_000_000
#0,P0
PUB main()
COGINIT(COGEXEC_NEW,@blink01,0) 'returns cog number started 1 PTRA set to 0
repeat 'processor clock speed
DAT ORGH 'HUBEXEC Ram
blink01 DIRH #P0
Loop OUTL #P0
waitLoop1 AUGD #(@cntDelay<<9)
waitx #(cntDelay & $1FF) 'Maximum 9 bit value not using register reference
debug("finnish waitLoop1")
OUTH #P0
waitLoop2 AUGD #(@cntDelay<<9)
debug("finnish waitLoop2")
jmp #Loop
cntDelay long 2_0000_0000
'using Cog memory Execute following program works
CON {Processor Timing}
#0,P0
PUB main()
DAT ORG 0 'Cog1 Blink
blink01 DIRH #P0
Loop OUTL #P0
waitLoop1 waitx cntDelay 'Maximum 9 bit value not using register reference
debug("goto Loop2")
OUTH #P0
waitLoop2 waitx cntDelay 'Maximum 9 bit value not using register reference
debug("goto Loop1")
jmp #Loop
Registers can only be in cog ram.
If you want to use hub you will need to use riling rdlong etc.
I think autocorrupt changed cluso’s rdlong to riling.
It takes three ~plus CR at the top and ~ plus CR at the bottom
Doesn't HUB Executing PASM code using 4 byte Memory in the HUB simulate Registers interperting the 32 bits as a PASM instrution? Wouldn't the code be 4 byte aligned in the HUB and the PC counter accesses this? I assumed (not a good way to start) that the PC in the cog accessed the HUB Memory and incremented by 4 bytes somehow. Wouldn't the HUB memory behave the same way cog memory does just with a larger address space. Both are actuall 8 bit word base?. What does riling mean?
Regards and thanks for reply
Bob (WRD)
A register reference is enough to get a 32 bit value, but as @Cluso99 has pointed out the registers are in the Cogram.
If that value hasn’t been stored in Cogram yet, you’d need to either load it from hubram, or construct it once in the setup code.
To construct it you would use something like an AUGS followed by a MOV to put the 32 bit literal into a cog register.
three back-ticks -> `
Yes ... but that's only for instruction fetch. Data (operand) fetch is another story. Many RISC architectures are what's called load-and-store. Propeller is one of them. Data is loaded into the general register set (cogRAM) using explicit load instructions, and similarly written back out using explicit store/write instructions.
Operands, excepting immediate data, otherwise have to be in cogRAM (the general register set).
https://forums.parallax.com/discussion/comment/1530605/#Comment_1530605
Hub ram has the initial spin boot program and it holds the PASM program which can either be HUBEXEC code COGEXEC code. The rdlong instruction requires you to know the hub address. How do you know where to declare symbol address with reference to ORGH and how do you declare adresses to be reference in HUB ram. I have looked at document on HUB but I don't understand the
organization of HUB ram. HUB Ram is 00400 to 7FFFF but Debug uses 16KB so really it is 00400 to 7BFFF . I believe there is 512KB in actual memory so the first hub memory is lost 00000 to 003FF? In any case how do declare hub ram address and then reference it in the PASM rdlong instructions.? Is there some info in documents I missed?
Regards and Thanks
Bob (WRD)
Again, there is a difference between execution and data access. Execution addresses between $00000 and $00400 will provide instructions from COG or LUT RAM.
Looking at the HUB RAM section of the Parallax Propeller 2 Documentation v35, I'll give my understanding of how it works.
Any of the hub memory access instructions (RDBYTE, RDWORD, RDLONG, WRBYTE, WRWORD, WRLONG, WMLONG, RDFAST, WRFAST, and the whole RFx and WFx family of instructions) will be able to access all of HUBRAM.
The HUBRAM address is specified in the S register and can cover the range of $00000 to $FFFFF.
In the current production chip the 512KB of HUBRAM appears twice: from $00000 to $7FFFF and again at $80000 to $FFFFF.
The debug/ROM section at the top of the memory map ($FC000 to $FFFFF) will be locked for writing under certain circumstances, and is described as being hidden from the $7C000 region when locked.
If a future version of the Prop2 with a full 1MB of HUBRAM is made then the HUBRAM won't repeat, and any code written to take advantage of the repetition will break.
When a COGINIT is performed, the S register contents will be loaded into PTRB of the started Cog. An offset from this address can be used to find the Hub address of any variables declared in the code. Another option, useful you want to read a specific Hub address, is to perform a SETQ of that address prior to the COGINIT. This Q register value is loaded into PTRA of the started Cog.
Has this addressed all of your questions?
There is a full 512 kB of hubRAM, just not all is accessible to everything. HubRAM addresses from $0 to $3ff are data (RDLONG etc) accessible only.
EDIT: Oh, and COGINIT can load cogexec code from there too. Pure Pasm programs are initially loaded at hubRAM $0 before COGINIT'd. Those are data accesses then.
Here's an example rework of above attempt:
'******************************************* 'Using HUB Memory Execute '******************************************* CON _clkfreq = 200_000_000 tpin = 56 ' LED on Eval Board PUB main() COGINIT(HUBEXEC_NEW,@blink01,@cntDelay) 'PTRA set to hubRAM address of cntDelay repeat 'processor clock speed DAT ORGH 'HUBEXEC Ram blink01 DIRH #tpin rdlong pa, ptra Loop OUTL #tpin '----------------------------------------------------------------------------- waitLoop1 waitx pa debug("finnish waitLoop1") OUTH #tpin '----------------------------------------------------------------------------- waitLoop2 waitx pa debug("finnish waitLoop2") jmp #Loop '------------------------------------------------------------------------------ cntDelay long 200_000_000
And another example that answers the question in the title:
'******************************************* 'Using HUB Memory Execute '******************************************* CON _clkfreq = 200_000_000 tpin = 56 ' LED on Eval Board DELAYTIME = 200_000_000 PUB main() COGINIT(HUBEXEC_NEW,@blink01,0) repeat DAT ORGH 'HUBEXEC Ram blink01 Loop DRVL #tpin waitx ##DELAYTIME 'the easy way debug("finnish wait1") DRVH #tpin AUGD #DELAYTIME 'with explicite augd waitx #DELAYTIME & 511 debug("finnish wait2") jmp #Loop
Thanks . I think I follow . PTRA gets the top of Symbol Address @cntDelay . The programmer must now refer to any subsequent symbol address from that reference. So the symbol names
cannot be used directly . If there was cntdelay2 long defined you cannot reference directly the address you would use ptra = @cntDelay +1. PTRA only gets the top of symbol variable at COGINIT execution.
You can't use ptra = @cntDelay2 or rdlong pa,@cntDelay2 . Is that correct? I Will try this out.
Regards
Bob (WRD)
There might be other solutions but, yeah, I think Chip intentionally didn't wanted Spin2 programs having known load address at compile time.
That certainly works when you are after a 32-bit immediate parameter for WAITX, but the original example showed attempts to use a location in hubram to hold the delay value.
As that wasn’t going to work alternatives that would work, but maintained the parameter as a variable, were offered. This may be important in situations where another part of the code adjusts the delay and modification of the AUGD + WAITX would be impractical.
Note that PTRA gets loaded with whatever parameter is specified in the COGINIT. In your first example that was 0. You might note that in @evanh code PTRA is used as an address to load the delay parameter into PA. It could just as easily have been used to load the parameter into another Cog address. If you had a series of long aligned data following cntdelay you could adjust the pointer value in PTRA to point to any of them.
So, PTRA initially points to cntdelay and you have a few options to use it to access cntdelay2:
SETQ blocksize-1 RDLONG Cogcntdelay, PTRA
RDLONG Cogcntdelay, PTRA++ ; auto-increment address by 4 bytes RDLONG Cogcntdelay2, PTRA++ ; auto-increment address by 4 bytes
RDLONG Cogcntdelay, PTRA ADD PTRA, #4 ; manually increment addresses by 4 bytes RDLONG Cogcntdelay2, PTRA
In each case
Cogcntdelay would be cntdelay
Cogcntdelay +1 would be cntdelay2
etc.
You can get nice names to work with by defining the addresses.
The different options have different advantages.
The block load maintains the order and spacing of the variables allowing a simple block write back to hubram, if that is needed. Edit: If you want to write back then it is safest to save a copy of PTRA somewhere before changing it.
The auto increment allows the block to be broken up between locations in Cogram should that be needed.
The manual increment allows parameters to be skipped if they aren’t needed in this cog.
If you prefer to keep most of the variable names a bit shorter you can use the plain versions ( cntdelay, etc.) for the variables in Cogram, and use something like ‘Hubparams’ for the beginning of the block in hubram.
