New kid on the block: Raspberry Pico - Page 2 — Parallax Forums
2»
  • @Cluso99 said:
    So, when you look at ARM for microcontrollers you see they are positioned (forget the ARM roots as that has been lost long ago) for HLL where the programmer is so far removed from the hardware with C that the swapping in and out of registers (by pushing and popping multiple registers) that the understanding of this overhead has been hidden.
    Ye, RP2040 is barely even "ARM" in the original sense. Original ARM architecture has A+(B<<n) -> C kinda ops with conditional exec. RP2040 is Thumb mode only, so while the ops do indeed exec in a single cycle, you need lots of 'em.
  • @Cluso99 said:
    From my point of view, the RP2040 is representing itself as a microcontroller. From this point of view, C is not the best language for this. Assembler IMHO is a requirement for obtaining the determinism. C just doesn’t cut it here. Now, when you look at the real uses of microcontrollers, there is a benefit of having some parts (deterministic) being undertaken in one core, while another (non-deterministic) executing in another core running a HLL eg C. This is why P1 and P2 are great micros. Now we are starting to see other multi core microcontrollers.
    So, when you want to do something unusual with the I/O there are just so many instructions being executed behind the scenes just to simply toggle a pin.
    This is because you have to
    • PUSH R1
    • load the pin base address LDA R1,#$0D
    • shift this with SHL R1,#24
    • now perform the output as H/L/invert/etc instruction
    • POP R1
    And I don’t think it will be that long before we see another addition adding more memory and cores, and I/O.
    It’s a shame it’s not RISC V but RPi has too much invested in ARM to switch, at least for some time.
    Well, the raspberry foundation does not have the goal to make the leading edge microcontroller for very time critical applications. Instead they focus on education and hobby usage. They did have in mind to have software available from start. I am not aware that there is µpython for risc V at the moment. (Although in my experience µpython has some severe difficulties with 2 cores.) And they definitely had to be lower price than ESP-32 boards with pico. Otherwise there would have been the option to use M4 or M7 which you can buy from others. Still Pico is certainly very much more powerful than picaxe or original atmel arduino hardware, which have been important in this market.
    At the moment I am astonished finding, that not so much the 8 cores but the slightly better adc and dac possibilities make P2 better suitable for my distortion analyser project than pico. And I am using VGA at least to help debugging, just because Taqoz has it built in. This was not planned but is nice. :-)
  • FYI:
    There is also the MMBasic interpreter that also supports C subs.
    They are also working on running a standalone C routine in the 2nd core:
    https://geoffg.net/Downloads/PicoMite/PicoMite_User_Manual.pdf
