How do I change the module name?
Mike Green
in Accessories
I have several WX WiFi Modules. Currently, these are in STA mode and appear to work. When I open a web browser (Safari) on the address of the module and navigate to the Settings page, the module name shows the default. If I change the module name field to something else, the change doesn't survive power cycling. It doesn't matter whether I click Save or Save to Flash before turning off power. The Settings page tells me the settings have been Saved or Saved to Flash, but the default module name is what shows up after the module finishes up initializing itself and I open the web browser again and navigate again to the module's Settings page.
Hi @"Mike Green"
It seems to be a known bug, perhaps solved some time ago:
https://forums.parallax.com/discussion/170962/wx-esp8266-module-name-and-simple-ide-discovery
Hope it helps...
Henrique
