Question about PASM 'MOV' instruction and 'WC' effect
                                  in Propeller 1
        Consider the two following instructions...
mov     AAA, #10 WC
mov     BBB, #511 WC
The Manual (v1.2) states on page 311:
If the WC effect is specified, the C flag is set to Value’s MSB.
What does this mean for Immediate values? To my mind it is ambiguous. It might mean that bit [8] is copied into the C flag (because immediate values are only 9 bits long). Or else it could mean that the immediate value is implicitly extended to 32 bits and then bit [31] is copied into the C flag. But is that extension signed or unsigned?
After instruction AAA, what is C?  I think probably 0.
After instruction BBB, what is C?
When the source is NOT an immediate value this is of course not ambiguous at all.
None of the instructions behave differently when given an immediate. So MOV with immediate always clears C.
Only when WC is specified.
Okay, good to know.
I'm using this to try to reduce the number of instructions that a serial port transmitter uses...
'expects: ui_ser_byteTX[7..0] to contain the 8-bit byte to send over serial. 'returns: nothing 'remarks: ui_ser_byteTX gets clobbered! UI_SERIAL_TX 'this MOV instruction also forces the C flag to 0 which we'll use as the START BIT... MOV ui_ser_bitCount, #10 WC '8 data bits + 1 start bit + 1 stop bit 'the above WC effect means that the C flag is now 0 (the MSB of #10 is zero) 'decorate the value by adding a STOP BIT (on the left)... or ui_ser_byteTX, #$100 '...and START BIT (on the right) to the value itself... rcl ui_ser_byteTX, #1 'C flag (0, see MOV above) is rotated into the LSB, acts as START BIT 'Now ui_ser_bitCount contains: %1_dddddddd_0 'and we'll shift them out to the right >>>, at the correct Baud rate... 'set up the bit timing mov ui_ser_time, CNT add ui_ser_time, UI_SER_BIT_TIME 'now we're all set to transmit the 10 bits :ui_ser_TXBitLoop rcr ui_ser_byteTX, #1 WC 'put the bit into the C flag muxc outa, UI_SER_TX_PIN 'put the bit (in the C flag) on the wire waitcnt ui_ser_time, UI_SER_BIT_TIME djnz ui_ser_bitCount, #:ui_ser_TXBitLoop UI_SERIAL_TX_ret ret...where "UI_SER_BIT_TIME" is a value that represents the Baud rate.
Thank you both.
Also, just FYI, because the manual doesn't tell you about it, MOVS/MOVD/MOVI and JMP(RET) produce the same C value as a CMP would
@Cabbage
If you are trying to reduce instructions, you should use the smart pin uart.
Also, you can replace
with
shl ui_ser_byteTX, #1 WC '0 is shifted into the LSB, acts as START BIT, C flag =0
It's the P1 he's talking about: no smart pins.
That's what I get for opening tabs with both P1 & P2 threads
I could try clipping off a couple of P2 IO pins and gluing them to the end of the P1. I'm pretty sure that would work.
edit: nope
You're right about the SHL instead of the RCL of course. I don't know what I was thinking when I wrote that.
Perhaps something like "Hmm, I need to shift in a zero from somewhere... but where? Zeroes are so hard to find these days aren't they?"
im a stupid
