flexspin compiler for P2: Assembly, Spin, BASIC, and C in one compiler - Page 87 — Parallax Forums
18485878990130
  • RaymanRayman Posts: 15,950
    Regarding gets() being slow... Did some testing and it seems specific to one of my custom boards with a P2 Edge module on it... Something strange must be going on there... Maybe the FTDI chip needs different programming settings or something...
  • @ersmith said:
    @TonyB_ said:
    deleted
    Sounds like there's a missing "ORG 0" at the beginning of the COG code.
    Solved now, thanks, too many late nights recently.
  • Can't TJNS D,#S branch from cog to LUT RAM, e.g. a short forward jump from $1DE to $200? FlexSpin gives an error for this and similarly for CALLPB.
    Is that legal? I thought relative branches have to stay inside the same RAM. Does PNut let you try this? And if so, does it actually work?
  • TonyB_TonyB_ Posts: 2,255
    edited 2021-07-07 11:31
    I think it is legal, but I can't use PNut to confirm.
    The BRANCH ADDRESSING section of the doc discusses DJxx, IJxx, TJxx, CALLPx and a few others. It states that "their immediate range is -256 to +255 instructions, relative to the instruction after the branch."
    I guess that a forward jump from the top of LUT RAM wraps around to the bottom of cog RAM for these call or jump to S** instructions.
  • evanhevanh Posts: 17,037
    edited 2021-07-06 22:21
    I tested the hardware ages back but can't quite remember the details. I think COGRAM<->LUTRAM worked fine but I'm not certain now. LUTRAM to HUBRAM was a bit screwy but did work with an offset calculation. Going back to LUTRAM was different but I've forgotten in what way. HUBRAM wrapping back to COGRAM at the zero boundary was super screwy in that it would fetch from COGRAM but the PC was above 1 MB. Which caused some predictably weird behaviour.
    Oh, it only works if branching. You can't walk from LUTRAM to HUBRAM with sequential fetches. Don't remember for COGRAM to LUTRAM but likely the same.
  • I remember that boundary crossing needs to be absolute addressed not relative.
    Not sure from where I got that.
  • Jumping to and from hub RAM is not relevant to the suspected FlexSpin problem with the S** group of instructions.
    I wasn't testing the assemblers. I was testing the hardware. But my memory is not clear on which test was what any longer ...
    edited 2021-07-07 11:33
    deleted
    edited 2021-07-07 00:00
    I've confirmed that a relative branch, with DJNF, from cogRAM to lutRAM, works as expected without quirks.
    PS: I had to hand code the machine code in Flexspin. The assembler gave me invalid offset ... as well as the error message.
    edited 2021-07-07 01:49
    Tidied it up. Requires flexspin, the attached wrapper, and open terminal (I use loadp2) for reporting:
    CON
        XTALFREQ    = 20_000_000                'PLL stage 0: crystal frequency
        XDIV        = 2                 'PLL stage 1: crystal divider (1..64)
        XMUL        = 10                    'PLL stage 2: crystal / div * mul (1..1024)
        XDIVP       = 4                 'PLL stage 3: crystal / div * mul / divp (1,2,4,6..30)
        LUT_reserved    = 8
    DAT                     'not Spin code
    ORG  0
    msec        jmp     #_diaginit
    xtalmul     long    XMUL
    hw_rev      long    0           'hubRAM addr $010 - unused reserved parameter - using to hold revA/B
    clk_freq    long    25_000_000      'hubRAM addr $014 - sysclock frequency, integer frequency in hertz
    clk_mode    long    0           'hubRAM addr $018 - clock mode config word, used directly in HUBSET
    asyn_baud   long    230_400         'hubRAM addr $01c - comport baud rate, integer baud in hertz
    _main
            mov bcdlen, #8
            setq2   #(lut4 - lut1 - 1)
            rdlong  0, ##@lut1          'copy into lutRAM at $200
            setq    #(cog5 - cog3 - 1)
            rdlong  cog3, ##@cog3           'copy into cogRAM at $180
            setq    #(cog2 - cog1 - 1)
            rdlong  0, ##@cog1          'copy into cogRAM at $0
            jmp #cog4
    report
            pop pa
            call    #itoh
            mov pa, ptra
            call    #puts
            jmp #$
    ORG  0
    cog1
            loc ptra, #msg_fail
            call    #\report            'has to be absolute encoded branch address
    cog2
    ORG  $180
    cog3
            loc ptra, #msg_fail
    cog4
            loc pa, #msg_start
            call    #puts
            mov pa, #100
    '       djnf    pa, #lut3           '7c Ec 7F FB
            long    $fb7fec7c
            loc ptra, #msg_fail
    cog5
    ORG  $200
    lut1
            loc ptra, #msg_fail
    lut3
            loc ptra, #msg_lut
    lut4
    ORGH $400
            loc ptra, #msg_fail
    msg_start   byte    "Start ... ",0
    msg_hub     byte    " in hubRAM",13,10,0
    msg_lut     byte    " in lutRAM",13,10,0
    msg_cog     byte    " in cogRAM",13,10,0
    msg_fail    byte    " fail :-(",13,10,0
    ' Subroutines
    #include    "init-diag.spin2"
    EDIT: Typos
    edited 2021-07-07 03:36
    A regression - Binary inversion operator gets following error:
    spin-compile-test.spin2:6: error: assignment to constantTEST_CONSTANT'`
    con
        TEST_CONSTANT = 10
    PUB begin()
        waitms( ~TEST_CONSTANT )
    Thanks, Evan. FlexSpin seems to get encoding right currently apart from incorrect S field = $1FF. Branch from ~$180 to $202 works. Next logical test would be ~$380 to $002.
    edited 2021-07-07 10:41
    Relative positive branch from $380 will land in hubRAM. Triggering hubexec and the FIFO.
    Testing that it seems to be precisely scaled as longwords below $400 and bytes from $400 up. Which makes sense given that is the documented addressing. So a relative branch of $100 from $380 in lutRAM will land at $480 in hubRAM.
    On the other hand, if there is no branch and you execute off the end of lutRAM it will wrap back to cogRAM, albeit with the program counter ticking along above $400, because hubexec will only trigger on a branch.
    And you can't walk off the end of cogRAM because the special purpose registers at the end of cogRAM will crash your code.
    Thanks for the extra testing, Evan.
    I think there might be something else apart from PC that wraps around from end of LUT RAM to start of cog RAM, from a discussion a few months ago.
    Thanks for checking this. I'll disable the error in flexspin then.
    con
      TEST_CONSTANT = 10
    PUB begin()
    No, the previous behavior was the incorrect one (unfortunately). "~" is documented to modify its operand, so it cannot be applied to a constant. I've verified this with openspin.
    Incidentally, ~x is not the binary inversion operator: it sign extends x from bit 7. Binary inversion would be !x
    edited 2021-07-07 12:25
    Huh, okay, I admit I assumed it's function. I don't really know Spin all the well. I struck the error when compiling Roger's video driver. I guess it's time to clarify with Roger what his intent is.
    EDIT: Duh! Of course Roger has already fixed it, and is now using the ! operator, with the newest release. Didn't think to check until I went hunting for the driver topic. O_o
    You better look over my testing example too. That result was for the hardware with the appropriate machine code, not Flexspin. The assembler also needs fixed.
    No, the bad code was just because a dummy address was inserted at the point of the error to stop the error from appearing again. Now that the error is disabled the assembler is generating the same bytes as the original LONG did (this is with the github version of flexspin).
    Oh, thanks for the info.
    Where exactly is the new flexspin.exe?
    flexprop5.5.1.zip is the same as before with bad code.
    It's the checked in source version. There hasn't been a new binary release (and likely won't be for a little while).
    aaaw! didn't do lut<->hub ;)
