Tachyon Boolean and Bit Manipulation
dbpage
I am exploring Tachyon 5.7 on P1 for a commercial product.
How can I manipulate bits and set/reset bits based on boolean logical tests?
For example: ShiftRight4longs(@Es) ' 128 bit shift register (no mask)
t := (Din<0) and (EAin>G2)
Es |= negx&t
PRI ShiftRight4longs(ptr)
long[ptr][3] >>= 1
long[ptr][3] |= long[ptr][2]<<31
long[ptr][2] >>= 1
long[ptr][2] |= long[ptr][1]<<31
long[ptr][1] >>= 1
long[ptr][1] |= long[ptr]<<31
long[ptr] >>= 1
where:
Din and EAin are values read in from i2c devices, G2 is a constant, E is a 128 bit shift register
Other methods count the number of bits set to 1 in a shift register as follows: PRI Sum(ptr,n) | i,j
' Return the number of bits set to "1"
' ptr = address of first long
' n = number of longs
i := 0
j := 0
repeat n ' 1 to n longs
i := long[ptr]
i := i - ((i >> 1) & $55555555)
i := (i & $33333333) + ((i >> 2) & $33333333)
i := ((i + (i >> 4)) & $0F0F0F0F)
j += ((i * ($01010101))>>24)
ptr += 4
return j
PRI SumBits(n)
' Return the number of bits set to "1" in 1 long n
n := n - ((n >> 1) & $55555555)
n := (n & $33333333) + ((n >> 2) & $33333333)
n := ((n + (n >> 4)) & $0F0F0F0F)
return (n * ($01010101))>>24
Forgive me if I ask questions that have obvious answers!
I found this http://www.forth.org/svfig/Len/bits.htm
I see that the appropriate reserved words and symbols are in the Tachyon dictionary.
The link resolves my not knowing how to leave the results of a boolean expression on the stack and gives these examples:
Example 1:
Leave a TRUE flag on the stack if A and B are unequal:
It is permissible but inadvisable to use A B - if ... then ...
Example 2:
Leave a TRUE flag on the stack if A and B are unequal AND B and C are unequal
You are in trouble if you use A B - C D - and
For example 7 4 - 7 3 - and will result in false. In other words, two non-false arithmetic quantities and to false.
This problem can be avoided if you always use 0<>.
For example, A B - 0<> C D - 0<> and
Even better here is A B <> C D <> and
If I have any more questions, I'll ask!
