Spin 2 for Beginners : Futaba S.BUS — Parallax Forums
JonnyMacJonnyMac Posts: 9,323
edited 2021-05-13 03:59 in Propeller 2
For those who have the FlySky FS-i6X transmitter and a receiver that need guidance on configuration to allow for S.BUS output, I've created the attached document to help out. I would suggest starting with this video so that you can see the process.
You'll need to have the receiver connected to 5v and paired with the transmitter so that we can set it for 10 channels (it defaults to 6). The attached image shows the connections via the i-BUS/S.BUS Servo connector on the receiver.
Here's a link to the full user manual:
-- https://files.banggood.com/2016/09/FS-i6X User manual.pdf
Updated code is attached -- includes Chip's addbits trick in the PASM2 section.
Thanks to everyone who participated.
