CALL / RET flags preserve — Parallax Forums
Hello,
Time for another explanation:
The documentation say that CALL pushes C and Z into stack along with address, and RET pops them back, however if you run this code, it seems that the flags are not preserved:
                mov     t1, #$08
                cmp     t1, #$08    wz  ' Z=1
        if_z    call    #func           ' reset Z ?
        if_z    mov     t1, #$FF
        if_nz   mov     t1, #$00
                debug(uhex_byte(t1))
                jmp     #$
func            cmp     t1, #$FF    wz  ' Z=0
                ret
t1              long    0
It should set t1=$FF but it is $00 meaning that Z is reset by the called function. To prove it, comment the wz effect on the func row, and the assignment is correct.
Also have some doubt about_ret_ because while the description for ret(instruction) say that the flags are restored (but apparently not), the description for_ret_ (prefix) does not!
What I'm missing ?
  • AribaAriba Posts: 2,695
    I think you need to write:
                    ret     wcz
    to restore the flags to the state they were at subroutine entry.
    Andy
  • RET WCZ restores C and Z.
    RET WC restores C only.
    RET WZ restores Z only.
    RET does not restore C or Z.
    _RET_ does not restore C or Z.
  • Yes, of course I missed the effects!
    It is also a logic behaviour because someone may want the calling function to change the flags in some cases.
    Thanks, sorry for the silly questions, I'm having lot of difficulties interpreting this documentation.
