P2 PASM 4xCOG Syncronize — Parallax Forums
pic18f2550pic18f2550 Posts: 400
edited 2021-04-30 10:57 in Propeller 2
I would like to know how to get 4 COGs in lockstep.
My idea is to use GETCT() to load the counter value and wait in the PASM part until it expires.
PUB main() | mode
  sync := GETCT() {{ Start all COGs (16sec to overflow}}
  sync := sync+256_000_000 * 4 {{ wait 4 sec }}
  cog[1] := pha1.ini(@sync, @p_array1, @s_array1, 64, 64)
  cog[2] := pha2.ini(@sync, @p_array2, @s_array2, 64, 64)
DAT
sync
        mov t0, ptra
        addct1 t0, #0 {{ 2 }}
sync1
{{ ==== SYNC }}
        waitct1 {{ 2+ }}
Translated with www.DeepL.com/Translator (free version)
  • Using waitatn ?
    The 4 cogs starts with waitatn, the spin code issues a cogatn(mask) with the 4-cogs bit set (after waiting a bit to allow all 4 to load and start).
    Just wondering.
  • I still have to make some preparations in some COGs.
    The syncronization comes only a little later in code.
    (this is not present in the example above).
  • You can use a variable to signal when the cogs are waiting, same technique used with P1.
    Try this:
    CON
        _clkfreq    = 160_000_000
    VAR
        byte ready[8]
    PUB main() | c1, c2, c3, c4
        c1 := coginit(16, @driver, @ready)
        c2 := coginit(16, @driver, @ready)
        c3 := coginit(16, @driver, @ready)
        c4 := coginit(16, @driver, @ready)
        repeat while ready[c1]==0 || ready[c2]==0 || ready[c3]==0 || ready[c4]==0
        cogatn((1 << c1) | (1 << c2) | (1 << c3) | (1 << c4))
        repeat
    DAT
                    org   $000
    driver
                    cogid   a       ' get our id and
                    add     a, ptra ' use as offset into the table
                    wrbyte  #$FF, a ' signal we are ready
                    waitatn         ' patiently wait...
                    getct   ct
                    debug(UDEC(ct))
                    jmp     #$
    a               res     1
    ct              res     1
  • That's pretty neat, @macca.
    I used the cnt to sync all 8 cogs in a p1 logging program. For that program i needed each cog to start precisely 1 clock after each other.
  • pic18f2550pic18f2550 Posts: 400
    edited 2021-08-16 11:29
    PASM
                    cogatn  #2
    Keeps the COG #2 running?
    Does this also work with multiple COGs at the same time?
  • evanhevanh Posts: 16,702
    edited 2021-08-16 11:58
    Yes, it's a bit-mask rather than an ID number. Value #2 is bit#1 so cog#1 gets the event. If value was #3 then cog#0 and cog#1 both get an attention event.
