1 cycle/long memory zero - Page 2 — Parallax Forums
2»
  • TonyB_TonyB_ Posts: 2,242
    edited 2021-03-28 00:10
    Improved way to fill hub RAM with 32-bit value in reg x (preserved):
    'fill hub RAM with 32-bit value in x
    'N.B. x is not changed, AUGD mask long avoided
            setd    .xlo,x
            mov     .xhi,x
            sets    .xhi,#511
            ror     .xhi,#9
            setq    #len-1
    .xhi    augd    #0-0
    .xlo    wrlong  #0-0,ptra
    SETS immediate could be changed for conditional AUGD.
    EDIT:
    Could save 4 longs in future with a new D-only AUGDR instruction:
    'AUGDR does not exist yet!
            setq    #len-1
            augdr   x           'next #D = x
            wrlong  #0-0,ptra
  • evanhevanh Posts: 17,017
    Nice trick. Though only saves the mask data.
    edited 2021-03-28 00:29
    Not only that, Evan, reg containing fill value is preserved.
    Also applicable to AUGS that is patched.
  • cgraceycgracey Posts: 14,288
    Good ideas.
    edited 2021-03-28 00:50
    @TonyB_ said:
    EDIT:
          setq    #len-1
          wrlong  #0-0,ptra
    I'd pondered that as well. But it's a very specific use, one that WRLONG the block copy hadn't been designed for even. Very few instructions would use such a prefix, not even RDLONG.
    EDIT: Would be better to have a block filling mechanism that didn't need double prefixing like that. Ie: SETQ3 that doesn't increment the cog register pointer.
    edited 2021-03-28 11:37
    @evanh said:
    @TonyB_ said:
    EDIT:
            setq    #len-1
            wrlong  #0-0,ptra
    I'd pondered that as well. But it's a very specific use, one that WRLONG hadn't been designed for even. Very few instructions would use such a prefix, not even RDLONG.
    Filling hub RAM with arbitrary values is very important. The quickest way to fill a block of cog registers currently is via hub RAM using fast block write immediate then fast block read, assuming block size is too big for hard-coding lots of 2-cycle MOVs.
    I agree that it would be better to avoid AUGD entirely. Maybe use SETQ/SETQ2 with Q[31]=1 to stop reg/LUT pointer incrementing.
    Wuerfel_21's original code rotates the fill register. Rotating it back costs a long, so my suggestion saves two longs overall.
    SETQ's are single operand, plenty of opcode space for more of those instructions.
    Oh, the span_color, I'd missed that somehow. And reading further back, it has indeed been copied from poly_color. So there is one more instruction in Wuerfel's code I hadn't counted.
