Can not compile flexspin in Linux.
frank freedman
                                  in Propeller 2
        Trying to compile flexspin in linux gets the following:
[frank@loki flexprop-5.2.0]$ make
which: no openspin in (/home/frank/.local/bin:/home/frank/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin)
Usage:
  make install
  make zip SIGN=signscript
make install copies flexprop to the INSTALL directory (default is /home/frank/flexprop)
for example to install in /opt/flexprop do:
    make install INSTALL=/opt/flexprop
make zip creates a flexprop.zip for Windows
    This requires cross tools and is probably not what you want
Note that the P1 version of flexprop depends on openspin being installed; if it is not,
  then only P2 support is enabled
Can not find the openspin in the source, and no directory /home/username/flexprop is created.
Edit: in my opinion openspin is a very nice tool which does not get the attention it deserved (perfect for spin development on non-windows platform)
@"frank freedman" : flexprop only needs openspin for P1 support (the P1 loader has a weird build process that only works with openspin, not flexspin). If you only care about the P2 then "make install" should work fine. I just tried it on an Ubuntu machine with no openspin installed and it was happy to build and create /home/username/flexprop. Did something go wrong when you tried it?
