Prop Tool 2.4.1 the print does not work. — Parallax Forums
I tried printing a prop2 program and it wiil not print.Printer error "default error" shows up.
I can print any other document.
There seem to be issue with printing from the prop tool.
Needs help with this issue.
Siri
PS: using HP printer - HP ENVY PHOTO 7858
  • Just printed with Propeller Tool 2.4.1 successfully.
    I think the issue may be with your printer setup.
    Siri
    Can you attach the SPIN2 program in an attachment? Will try and replicate.
  • @Publison @ Ken Gracey
    I just printed test page and it printed with no issues.The printer works with 2 desktops,a lap top and IPad.
    Attach is the file I was trying to print.
    Is the issue solved?
  • @Publison
    The issue is not solved. I can print documents from other programs - word, express PCB, Blockly prop etc. Only Prop Tool has the issue.
    Thanks for helping.
    Siri
  • Ken GraceyKen Gracey Posts: 7,415
    edited 2021-02-15 14:23
    Summoning @"Jeff Martin" to take a look.
    I'm not sure if the @name is actually working the way it used to by creating a message to the person; anybody know?
    @Publison
    Thanks for helping.
    Siri
    When you go to"PRINT" choose "SETUP" to make sure it's going to the correct printer.
    It's working here fine.
