Why doesn't this work? Passing an object symbol
OBJ objA : "object_name" objB : "object_name" PUB go() private(objA) 'private(@objA) -- doesn't work 'private(@@objA) -- doesn't work PRI private(object)
I keep getting this error message (the error pointer is right at the end of objA):
The code from the child object is compiled with the parent object so the name of the object is not saved to RAM. The object name is just used by the compiler.
I use a "programName" string at the top of many of my Spin and Spin2 programs.
DAT programName byte "_ZOledAttempt210131a.spin2", 0I add an "objectName" to a DAT section in many of my objects.
DAT objectName byte "OledBootFlash210203b.spin2", 0Place the strings "programName" and "objectName" on line #1 of both objects. This makes it easier for me to update them with a date code.
I include the following method in the child object so the parent object can access the child object's name.
Here's an example of how these strings are used.
OBJ Usb : "jm_fullduplexserial" { Uses one cog.} Flash : "OledBootFlash210203b" { Uses one cog.}PUB DisplayMenuHeading() Usb.Tx(Usb.CLR_EOL){ These three commands should clear the bottom of menu.} Usb.Tx(Usb.CR) Usb.Tx(Usb.CLR_DN) Usb.Tx(Usb.HOME) { Start menu at top.} {Start by identifying which program is running.} Usb.Str(string(11, 13, "programName = ")) Usb.Str(@programName) Usb.Str(string(11, 13, "flash object name = ")) Usb.Str(Flash.GetObjectName())Edit: I had to change the way comments were written in order to get the code blocks to work.
Ah, I was under the mistaken impression that these "children" object files were treated like real objects/structures, like in C++, where each instantiation was assigned an address and their methods and attributes were offsets from that address.
My understanding was that the CONSTANTS for a "child" object were compiled into one location and all the instances of that object used the same address of that CONSTANT. I was trying to eliminate redundant code by using the CONSTANT at a CLASS level. I could have just accessed the CONSTANT from one of the instances but that looks weird.
What I ended up doing was creating CONSTANTS in the parent object that referenced the CONSTANTS in one of the instances. It doesn't look as weird using it that way.
Thanks, @"Duane Degn"
I do something very similar to what you illustrated above for storing versioning information and menu items within each child. The parent than makes calls to the child so it can build a master menu of available functions.
FWIW I often have a "shared constants" ojbect which is included in multiple child objects.
Constants don't increase the size of a program but the Propeller Tool has a limit to how many can be created. I have run out of constants many times.
