Trying to retrieve time from ds3231 to display on the LCD
                                  in Propeller 2
                    I am using the christmas P2 bundle and I am follwing jonnymacs beginners guides.
I am able to get text to appear on the lcd but Iam trying to get the time from ds3231 to show on the Lcd.
I tied t the way i used inP1 but no luck.
I need help .
Thank you
Siri
I need help .
Thank you
Siri
Thank you, I knew you are going to help me.
You did help me when i was building the infant ventilator using P1 and I tested on a baby pig
and i t worked as it was intended.
Thank you again for your time.
Siri
I did not get it to work, but I knew from P1 I had to read a byte at a time and I was working on it.
Thanks for your code , that was exactly what I was trying to do. Now I am studying your to see
why and where I got it wrong.
This keeps my mind occupied most of the day and learning some thing new.
Thanks again for the help - " keeping my neurons alert/active and busy"
Siri
