how to detect overflow with SUMC? — Parallax Forums
The SUMC instruction is very useful if I want to add or subtract a value from a register based on the C flag. But how can I detect an over or underflow? I don't quite understand the stament "C = correct sign of (D +/- S)" in the docs.
What I like to do:
* if C is 0 then add S to D, set C if an overflow occurs (boundary $FFFFFFFF to $00000000 is crossed)
* if C is 1 then subtract S from D, set C if an underflow occurs (boundary $00000000 to $FFFFFFFF is crossed)
Is this possible with the SUMC instruction? Or do I have to split the operation into something like this?
  MODZ ... ' put C into Z
  if_z  SUB D,S wc
  if_nz ADD D,S wc
BTW, where are those constants defined that specify the actions for the MODC/Z instructions? Can't find them in the docs, again.
  • evanhevanh Posts: 17,142
    edited 2021-01-09 15:36
    ManAtWork wrote: »
    I've forgotten exactly. I remember the discussion over naming of that but the name, "correct sign", no longer makes it clear for me either. TonyB put a lot of effort into ensuring the carry flag functioned better in the prop2.
    EDIT: Here's the original conversation - http://forums.parallax.com/discussion/167295/c-after-cmps-cmpsx-adds-addsx-subs-subsx/p1
    The list is in instructions.txt in PNut zip, and now also added to end of main hardware google doc.
  • ManAtWork wrote: »
    What I like to do:
    This should be what you're looking for (untested):
    sumc d,s wc
    testb d,#31 xorc
    Wuerfel_21 wrote: »
    sumc d,s wc
    testb d,#31 xorc
    Looks right as per http://forums.parallax.com/discussion/comment/1421463/#Comment_1421463
  • Wuerfel_21 wrote: »
    sumc d,s wc
    testb d,#31 xorc
    I've just tested it. The idea is good but the results are a bit different:
    * if C is 0 then add S to D, set C if a signed overflow occurs (boundary $7FFFFFFF to $80000000 is crossed)
    * if C is 1 then subtract S from D, set C if a signed underflow occurs (boundary $80000000 to $7FFFFFFF is crossed)
    However, that is not a problem for me. I can just add an offset to D. The exact number where the C bit is set doesn't really matter. It's only important that it happens once per "revolution" and at the same point when turning backwards.
    Yeah, SUMxx instructions will be signed. You can tell because in the instruction sheet it says C = correct sign, where as for unsigned instructions it says C = carry.
  • Just to add, "correct sign" means that even if there is an overflow and therefore the result is nonsense, C is always the the correct sign for any signed addition/subtraction, thus one can do a compare and not worry about a possible overflow. I came up with the term "correct sign" as it starts with the letter C.
  • An alternative that I think would actually trigger at the zero-crossing, but requires the Z flag (still untested):
    testb d,#31 wz
    sumc d,s wc
    ' now use if_diff/if_same conditions instead of if_c/if_nc
  • Don't forget about TJV !
    TonyB_ wrote: »
    Yes, TJV is what they're looking for.
  • AFAICS, TJV does test for the exact same condition as Wuerfels proposal.
    TJV Test D and jump to S** if D overflowed (D[31] != C, C = 'correct sign' from last addition/subtraction).
    I mean, "D[31]!=C" is the same as "testb d,#31 xorc".
    Thanks for the solution
  • TJV is useful for more than testing overflow.
    edited 2021-01-11 07:45
    I've dug up the old test code for this. It was very early stuff so needed some work to interface with my current setup. Here's a fresh set results with some extras added:
    00000004(reg1) + 00000005(reg2) = 00000009
    00000004(reg1) - 00000005(reg2) = ffffffff
    Collected flags = 0000028a
    ADD  reg1,reg2:  C = 0,  Z = 0
    SUB  reg1,reg2:  C = 1,  Z = 0
    CMP  reg1,reg2:  C = 1,  Z = 0
    ADDS reg1,reg2:  C = 0,  Z = 0
    SUBS reg1,reg2:  C = 1,  Z = 0
    CMPS reg1,reg2:  C = 1,  Z = 0
    00000005(reg1) + 00000004(reg2) = 00000009
    00000005(reg1) - 00000004(reg2) = 00000001
    Collected flags = 00000000
    SUB  reg1,reg2:  C = 0,  Z = 0
    CMP  reg1,reg2:  C = 0,  Z = 0
    SUBS reg1,reg2:  C = 0,  Z = 0
    CMPS reg1,reg2:  C = 0,  Z = 0
    80000000(reg1) + 80000000(reg2) = 00000000
    80000000(reg1) - 80000000(reg2) = 00000000
    Collected flags = 00000d75
    ADD  reg1,reg2:  C = 1,  Z = 1
    SUB  reg1,reg2:  C = 0,  Z = 1
    CMP  reg1,reg2:  C = 0,  Z = 1
    ADDS reg1,reg2:  C = 1,  Z = 1
    SUBS reg1,reg2:  C = 0,  Z = 1
    CMPS reg1,reg2:  C = 0,  Z = 1
    7fffffff(reg1) + 7fffffff(reg2) = fffffffe
    7fffffff(reg1) - 7fffffff(reg2) = 00000000
    Collected flags = 00000145
    7fffffff(reg1) + 80000000(reg2) = ffffffff
    7fffffff(reg1) - 80000000(reg2) = ffffffff
    Collected flags = 000002a0
    ADDS reg1,reg2:  C = 1,  Z = 0
    80000000(reg1) + 7fffffff(reg2) = ffffffff
    80000000(reg1) - 7fffffff(reg2) = 00000001
    Collected flags = 0000002a
    80000000(reg1) + 80000001(reg2) = 00000001
    80000000(reg1) - 80000001(reg2) = ffffffff
    Collected flags = 00000aaa
    ADD  reg1,reg2:  C = 1,  Z = 0
    80000001(reg1) + 80000000(reg2) = 00000001
    80000001(reg1) - 80000000(reg2) = 00000001
    Collected flags = 00000820
    7fffffff(reg1) + ffffffff(reg2) = 7ffffffe
    7fffffff(reg1) - ffffffff(reg2) = 80000000
    Collected flags = 00000a80
    ffffffff(reg1) + 7fffffff(reg2) = 7ffffffe
    ffffffff(reg1) - 7fffffff(reg2) = 80000000
    Collected flags = 0000080a
