We have a 10 year-old using the P2: here's his first results!
Kevin started with a teacher-donated Boe-Bot (a really old one with the white Delrin CNC wheels) and he started to interface sensors we don't support in the kit, so he was learning on his own. When we saw this, I invited him to the P2 Live Forum to see if it resonated with him. You may have seen him and his mom's face glued to the Zoom screen last week as they soaked it in. @"David Betz" sponsored a P2 Holiday Kit and we supported him with a P2 Developer Bundle. We shipped Monday and he received it today (that's why he dropped off the P2 Live Forum; you may have seen him wave the sign "Ken and David, we got the kit!!").
Within minutes: https://youtu.be/qsAtFKCrnLY
You can imagine that he's excited for the @JonnyMac presentation tomorrow. Getting to add an encoder to this lighting system would make him rightfully full-berserk. It's amazing how that when we were his age we dreamed of having an Atari 2600 or a manual milling machine. And, this young person has his own eight-core 200 MHz multicore microcontroller kit!
Wonder why Kevin is so interested when so many youngsters are NOT.
Parents perhaps?
Be interesting to know.
Will Kevin be the designer of prop4????
Dave
Always hire people smarter than yourself, right?
"Just the standard code, but with mods"
Perfect! I got a nice warm fuzzy seeing and hearing him getting cool stuff done.
This kind of thing seems to lift me (probably a lot of us) up and able to shake the funk of crappy times right off.
I just realized these addressable LED'S could work for a long running desire I have had and that is xmas lights with actual twinkling. We all are likely to have grown up with the colored, incandescent flasher bulbs. They all blink at a different rate depending on the little contact spring inside. Looks like it is time to bring the twinkle back without the fire hazard.
Please tell him he has a fan and that I am going to make some spiffy lights of my own for next year.
Sir potatohead, if you're thinking of anything using these addressable LEDs, you have the finest code base from which to start. Between JonnyMac's driver and Stephen Moraco's HUB75 system nobody needs to look any further. Reliable, easy to use code is now available. The only problem people need to sort out is how to come up with a huge 20A/5V power supply to control the biggest system they can envision.
What is HUB75?
When I grow up I want to be as smart as Kevin.
Absolutely amazing!
Just goes to show what a bright child can do with good parental encouragement.
Good to see.
Dave
Got it! Windows loads it fine.
Chip... this could be your next lab tech!
Provided he gets a VM running on his Linux box so he can have both Prop Tool and Zoom, he'd like to share his project at 3:00 pm Pacific.
So, I'll set up a P2 Live Forum for Tuesday and if Kevin shows up we'll learn about his project.
