Looking a the Flexspin docs, and the section "### Changing Hub address"...
It appears like I could compile some small app that could be copied over from uSD, say, at run time end then do something like this on it:
flexspin -2 -H 0x10000 -E fibo.bas
Would that work? If so, what's a good strategy for keeping it away from stack and heap?
Yes, that would work to compile fibo.binary that could be loaded and run from another program. You'd have to make sure that the calling program (the one that invokes fibo.binary) plus its stack fits below 0x10000. The heap is statically sized in FlexProp, so it's already included in program size. That just leaves the stack, and there's no general way to calculate the stack size required (it's equivalent to the halting problem, IIRC) but if the program doesn't have recursion you can usually figure it out. As a rule of thumb hardly any programs need more than 4K of stack, unless they declare big local arrays.
Eric,
I just assembled Chip's HDMI demos from Pnut v35 and discovered he is using a new mnemonic: ASMCLK - for inserting canned function of setting the default sysclock according to _clkfreq constant.
Interestingly, Flexspin does not complain about this when assembling. But it doesn't do the right job either. Indications are ASMCLK is ignored and the sysclock is left at RCFAST.
00000 | CON hdmi_base = 48 'must be a multiple of 8
00000 |
00000 | _clkfreq = 250_000_000 'system clock frequency must be 250 MHz for HDMI
00000 |
00000 | fast = 1 '0 for small code (7.8 fps), 1 for fast code (36.6 fps)
00000 |
00000 | bitmap = $400 'HDMI bitmap (300 KB)
00000 |
00000 000 | DAT org
00000 000 |
00000 000 | asmclk
00000 000 |
00000 000 00 00 00 FF
00004 001 10 02 EC FC | coginit #1,##@pgm_hdmi 'launch HDMI
00008 002 00 00 00 FF
0000c 003 A0 00 EC FC | coginit #0,##@pgm_bmap 'launch bitmap cog
@evanh: I think it was interpreting the "asmclk" as a label.
I'm not sure if I can support "asmclk" or not. It seems like a pretty dangerous feature: if someone wants to insert some assembly instructions I think they should write them out rather than having the compiler mysteriously insert them.
When I was having jitter problems, Chip recommended a change from dividing down to 0.5MHz to divide down to 3MHz, multiply up to 297MHz and then divide by 2.
{{'P2D2
_XTALFREQ = 12_000_000 ' crystal frequency
''_XDIV = 12 * 2 '\ ' crystal divider to give 0.5MHz
''_XMUL = 297 '| 148.5MHz ' crystal / div * mul
''_XDIVP = 1 '/ ' crystal / div * mul /divp to give _CLKFREQ (1,2,4..30)
_XDIV = 4 '\ '\ crystal divider to give 3.0MHz
_XMUL = 99 '| 148.5MHz '| crystal / div * mul to give 297MHz
_XDIVP = 2 '/ '/ crystal / div * mul /divp to give 148.5MHz
_XOSC = %01 'OSC ' %00=OFF, %01=OSC, %10=15pF, %11=30pF
My frequency spanning tests are pretty much all done with adjusting XMUL alone. I don't bother with trying to get 0.5 MHz steps. I'll just round up instead. It's not like it matters.
setclkfrq
getqx inb 'get excess results, final one sets event flag
jnqmt #setclkfrq 'wait for flag to collect final results - CORDIC pipeline flushed
'recalculate sysclock hertz using cordic
qmul xtalmul, ##(XTALFREQ / XDIV / XDIVP) 'integer component of pre-divided crystal frequency
mov pa, xtalmul
mul pa, ##round((float(XDIV*XDIVP)+0.5) * (float(XTALFREQ)/float(XDIV)/float(XDIVP) - float(XTALFREQ/XDIV/XDIVP)))
qdiv pa, ##(XDIV * XDIVP) 'fractional component of pre-divided crystal frequency
getqx clk_freq 'result of integer component
getqx pa 'result of fractional component
add clk_freq, pa 'de-error the integer rounding
The newly calculated clk_freq is then used to recalculate and set the serial port timings to keep the same baud:
'recalculate baud divider (clk_freq / asyn_baud) of diag comport using cordic
' low bauds won't operate at high sysclocks, the divider only has 16-bit reach
qdiv clk_freq, asyn_baud 'comport divider
qfrac #1, asyn_baud 'remainder scale factor, 2**32 / baud
getqx pa 'comport divider
getqy pb 'divider remainder, for .6 fraction
getqx temp1 'scale factor
qmul pb, temp1 'convert remainder to a "big" fraction
getqx pb 'fractional component of comport divider
rolword pa, pb, #1 '16.16 comport divider
sets pa, #7 'comport 8N1 framing (bottom 10 bits should be replaced but 9's enough)
call #waittx
wxpin pa, #DIAGTXPIN 'set tx baud and framing (divider format is 16.0 if divider >= 1024.0)
wxpin pa, #DIAGRXPIN 'set rx baud and framing (divider format is 10.6 if divider < 1024.0)
And finally, the new sysclock mode is set:
'adjust hardware to new XMUL sysclock frequency
andn clk_mode, #%11 'clear the two select bits to force RCFAST selection
hubset clk_mode '**IMPORTANT** Switches to RCFAST using known prior mode
mov clk_mode, xtalmul 'replace old with new ...
sub clk_mode, #1 'range 1-1024
shl clk_mode, #8
or clk_mode, ##(1<<24 + (XDIV-1)<<18 + XPPPP<<4 + XOSC<<2)
hubset clk_mode 'setup PLL mode for new frequency (still operating at RCFAST)
or clk_mode, #XSEL 'add PLL as the clock source select
waitx ##25_000_000/100 '~10ms (at RCFAST) for PLL to stabilise
hubset clk_mode 'engage! Switch back to newly set PLL
@ersmith FlexProp V5.0.1-beta has some new issues in the BASIC side of the house:
1). The following syntax variations all throw the error: "syntax error, unexpected shl, expecting $end or end of line or end or ':'"
x >> 1
x SHR 1
x << 1
x SHL 1
However, if you write them this way, they all work fine:
x = x >> 1
x = x SHR 1
x = x << 1
x = x SHL 1
The allowable syntax has changed somewhere along the line, because the first syntax used to be legal (and it's actually found verbatim on page 66 in the FlexBASIC manual). When it changed I can't tell you, but today when I pulled some old and tested code out, the compiler got grumpy at this.
2). The OCT$(), BIN$(), HEX$() functions all return an empty string if the GUI menu option "Options->Full Optimization" is selected. There is no error thrown at compile time. Changing the optimization level to "Default" fixes the problem.
@ersmith
x >> 1
x SHR 1
x << 1
x SHL 1
x = x >> 1
x = x SHR 1
x = x << 1
x = x SHL 1
It never should have accepted it, and it wouldn't have done anything even if it did. The documentation is poorly written here. "x >> 1" is syntactically the same as "x + 1", that is it's an expression that returns a new value based on "x" and which leaves "x" itself unchanged. The documentation incorrectly implies that it modifies "x", but that has never been the case. I'll fix the docs.
Thanks for the bug report, it's an error in the loop-reduce optimization. I'll try to fix that soon.
@JRoark: there's an off-by-one error in include/libsys/strings.bas. It's fixed in github now, but the patch is simple and you can apply it locally:
diff --git a/include/libsys/strings.bas b/include/libsys/strings.bas
index c2130fe0..39796e19 100644
--- a/include/libsys/strings.bas
+++ b/include/libsys/strings.bas
@@ -112,7 +112,7 @@ function number$(val as uinteger, n as uinteger, B as uinteger) as string
' we have to watch out for overflow in very large
' numbers; if tmp wraps around (so tmp < last tmp)
' then stop
- while tmp < val and lasttmp < tmp
+ while tmp <= val and lasttmp < tmp
lasttmp = tmp
tmp = tmp * B
n = n + 1
@ersmith A question about strings and garbage collection in FlexBASIC:
Assume that I create a string: A$ = "This is a test". This will be stored with a trailing 00h to mark the end of the string. Now assume that I remove the trailing 00h, and replace the space character between "THIS" and "IS" with a 00h.
Question 1: When the GC runs, will it reclaim *all* of the space that was originally used by the string, or will it hit that new 00h at offset 5 and quit, thereby leaving part of the original string unreclaimed?
Question 2: Does _gc_free(myvar) actually reclaim the space used by "myvar" or does it just mark it as being unused so the next time _gc_collect() runs it gets reclaimed?
I'm trying to locate a very slow memory leak/corruption problem that takes days to manifest itself, and these two scenarios seem to be possibilities.
The gc does not operate on strings, it operates on blocks of memory. The contents of the memory are not relevant and are not even looked at. So no, modifying the internal bytes of the string won't make any difference (trying to write past the allocated memory might, but that would definitely be a bug).
It actually reclaims it.
Note that the Achilles heel of the flexprop memory allocator is fragmentation. Memory is never moved, so if there are a lot of allocations and frees of different sizes, and some of those in the middle are not freed, then even though there may be enough freed memory in total for an allocation there may not be enough contiguous memory. As an illustrative example (it may not be exactly accurate), there may be 4K in use and 12K free, but that 12K might be split up in such a way that you cannot allocate more than 1K of it, if the 4K used is in small blocks located in bad places. There's no way of analyzing this at present. If I have time I may try to add a way to find the largest free block.
@ersmith That explanation helps me a LOT. Thanks for taking the time to explain it so well. This suggests to me that the way/order that I define the bigger things in the main code body is important, ie, keep structures together that dont get deallocated, and allocate the smaller/on-the-fly stuff later.
It would be wonderful to have a means of compaction... but there are likely a few (hundred) things higher on the “need it” list! Lol.
It's earlier in the thread, but yes, there's currently a bug in the 9p file system that causes reads/writes greater than 1K to fail. That's fixed in github and things will work properly in the upcoming 5.0.3 release.
void TestPwm ()
int ampl= 0x0100;
int theta;
for (theta=0; true; theta+= 0x01000000);
__asm {
qrotate ampl,theta
but this doesn't?
void TestPwm ()
int ampl= 0x0100;
for (int theta=0; true; theta+= 0x01000000);
__asm {
qrotate ampl,theta
It throws an error message "undefined symbol theta". I thought loop variables and local function variables are both held in registers. If it's not legal to use a loop variable in assembler the compiler should say so.
@ersmith It looks like the FlexBASIC += operator doesn't like to be used with array variables:
It seems to think that Thing(i) is a function instead of an array?
Edit: The same error gets thrown for all of the compound operators: +=, -=, *=, /=, and=, or=, xor=.
Thanks for catching this bug, it'll be fixed real soon now. The problem is that syntactically BASIC array refs look like function calls, and there's some hackery to fix up apparent function calls that are really array references. But some code for dealing with += and the like gets called before that fixup, so triggers the error. It shouldn't be hard to work around.
Invisible insertion is not a good idea, but Assemblers do commonly support macros, and there, the code appears clearly in the listing file, showing exactly what was done by the macro.
XTALFREQ = 20_000_000 'PLL stage 0: crystal frequency XDIV = 20 'PLL stage 1: crystal divider (1..64) XMUL = 300 'PLL stage 2: crystal / div * mul (1..1024) XDIVP = 1 'PLL stage 3: crystal / div * mul / divp (1,2,4,6..30) ' Clock modes ' %0000_000e_dddddd_mmmmmmmmmm_pppp_cc_ss ' enable oscillator XOSC = %10 ' OSC ' %00=OFF, %01=OSC, %10=15pF, %11=30pF XSEL = %11 ' XI+PLL ' %00=rcfast(20+MHz), %01=rcslow(~20KHz), %10=XI(5ms), %11=XI+PLL(10ms) XPPPP = ((XDIVP>>1) + 15) & $F ' 1->15, 2->0, 4->1, 6->2...30->14 _clkfreq = round(float(XTALFREQ) / float(XDIV) * float(XMUL) / float(XDIVP)) CLK_MODE = 1<<24 | (XDIV-1)<<18 | (XMUL-1)<<8 | XPPPP<<4 | XOSC<<2 DAT org hubset ##CLK_MODE 'config PLL waitx ##25_000_000 / 200 'allow crystal+PLL 5ms to stabilize hubset ##CLK_MODE | XSEL 'switch to PLL ...I know it's an example but would you really use these XDIV & XMUL for 300 MHz?
EDIT:
Maybe you just changed XMUL that was 297?
{{'P2D2 _XTALFREQ = 12_000_000 ' crystal frequency ''_XDIV = 12 * 2 '\ ' crystal divider to give 0.5MHz ''_XMUL = 297 '| 148.5MHz ' crystal / div * mul ''_XDIVP = 1 '/ ' crystal / div * mul /divp to give _CLKFREQ (1,2,4..30) _XDIV = 4 '\ '\ crystal divider to give 3.0MHz _XMUL = 99 '| 148.5MHz '| crystal / div * mul to give 297MHz _XDIVP = 2 '/ '/ crystal / div * mul /divp to give 148.5MHz _XOSC = %01 'OSC ' %00=OFF, %01=OSC, %10=15pF, %11=30pF }}The newly calculated clk_freq is then used to recalculate and set the serial port timings to keep the same baud:
1). The following syntax variations all throw the error: "syntax error, unexpected shl, expecting $end or end of line or end or ':'" However, if you write them this way, they all work fine: The allowable syntax has changed somewhere along the line, because the first syntax used to be legal (and it's actually found verbatim on page 66 in the FlexBASIC manual). When it changed I can't tell you, but today when I pulled some old and tested code out, the compiler got grumpy at this.
print hex$(15) 'prints "F". OK print hex$(16) 'prints "0". Not "10". Whoops. print hex$(17) 'prints "11. OK print hex$(255) 'prints "FF". OK print hex$(256) 'prints "00". Not "100". Whoops. print hex$(257) 'prints "101. OK print hex$(4095) 'prints "FFF". OK print hex$(4096) 'prints "000". Not "1000". Whoops. print hex$(4097) 'prints "1001". OKIt appears that the switch from having 2 chars returned, to 3 chars returned, isn't being handled properly?
diff --git a/include/libsys/strings.bas b/include/libsys/strings.bas index c2130fe0..39796e19 100644 --- a/include/libsys/strings.bas +++ b/include/libsys/strings.bas @@ -112,7 +112,7 @@ function number$(val as uinteger, n as uinteger, B as uinteger) as string ' we have to watch out for overflow in very large ' numbers; if tmp wraps around (so tmp < last tmp) ' then stop - while tmp < val and lasttmp < tmp + while tmp <= val and lasttmp < tmp lasttmp = tmp tmp = tmp * B n = n + 1Assume that I create a string: A$ = "This is a test". This will be stored with a trailing 00h to mark the end of the string. Now assume that I remove the trailing 00h, and replace the space character between "THIS" and "IS" with a 00h.
void cFFFFFF(byte v) { union { uint32_t c; uint8_t b[4]; }; b[0] = v; b[1] = 0xff; b[2] = 0xff; b[3] = 0xff; cmd32(c); }No, this is a not-technically-standard thing that most compilers just happen to support because it's useful.
int n; while ((n = fread(LogBuf, 1, 1000, f)) > 0) //RJA we seem to have a limit somewhere between 1000 and 2000 {If we rewrite it like below, then it works fine. It seems to think that Thing(i) is a function instead of an array?
void TestPwm () { int ampl= 0x0100; int theta; for (theta=0; true; theta+= 0x01000000); { __asm { qrotate ampl,thetabut this doesn't?void TestPwm () { int ampl= 0x0100; for (int theta=0; true; theta+= 0x01000000); { __asm { qrotate ampl,thetaIt throws an error message "undefined symbol theta". I thought loop variables and local function variables are both held in registers. If it's not legal to use a loop variable in assembler the compiler should say so.Thanks for catching this bug, it'll be fixed real soon now. The problem is that syntactically BASIC array refs look like function calls, and there's some hackery to fix up apparent function calls that are really array references. But some code for dealing with += and the like gets called before that fixup, so triggers the error. It shouldn't be hard to work around.
