[Abandoned] Porting keyboard.spin for P2 (keyboard2.spin2)
doggiedoc
For the last few days I have spent way too much time trying to get Chip's PS/2 keyboard driver for P1 to compile and work in for P2. I'm starting to think I'm in way over my paygrade.
I've got it to compile in PropTool 2.4 now but it is does not function.
Changes (may not be complete list):
(1)added ( ) to each method
(2)replaced cognew statement:
P1
(3)changed pasm subroutines ":" to p2asm "."
(4)replaced movd with setd and par with pa
P1
(5)edited "data" to "dayta" in each occurrence and "configure" to "cnfigure" because PropTool 2.4 change code blocks incorrectly. (may be other examples)
(6)modified rev
P1
(7)there is no if_never prefix in p2asm
so this block is troublesome: I removed if_never prefix so it compiles but I don't think it executes properly.
The (if_never replacements) code is part of the original driver
(8) added 2 zero-bytes to shift1, else get "cog symbol must be long-aligned" error
Any advice or insight would be greatly appreciated!
I've attached the modified file below and demo with supporting files.
Paul
P1
okay := cog := cognew(@entry, @par_tail) + 1P2
okay := cog := coginit(COGEXEC_NEW, @entry, @par_tail) + 1
P1
entry movd :par,#_dpin 'load input parameters _dpin/_cpin/_locks/_auto
mov x,par
add x,#11*4
mov y,#4
:par rdlong 0,x
add :par,dlsb
add x,#4
djnz y,#:par
P2
entry setd .par,#_dpin 'load input parameters _dpin/_cpin/_locks/_auto
mov x,pa
add x,#11*4
mov y,#4
.par rdlong 0,x
add .par,dlsb
add x,#4
djnz y,#.par
(6)modified rev
P1
. rev data,#-3 & $1FP2
. rev dayta
zerox dayta,#-3 & $1F
' Wait for clock/data to be in required state(s)
wait_c0 mov wcond,c0 '(wait until clock low)
wait mov y,tenms 'set timeout to 10ms
wloop movs napshr,#18 'nap ~4us
call #nap
_c3 test cmask,ina wc 'check required state(s)
_d4 test dmask,ina wz 'loop until got state(s) or timeout
wcond if_never djnz y,#wloop '(replaced with c0/c1/c0d0/c1d1)
tjz y,#reset 'if timeout, reset keyboard
wait_ret
wait_c0_ret ret
c0 if_c djnz y,#wloop '(if_never replacements)
c1 if_nc djnz y,#wloop
c0d0 if_c_or_nz djnz y,#wloop
c1d1 if_nc_or_z djnz y,#wloop
keypad1 byte $CA, $C5, $C3, $C7, $C0, 0, $C1, $C4, $C2, $C6, $C9, $0D, "+-*/"
keypad2 byte "0123456789.", $0D, "+-*/"
shift1 byte "{|}", 0, 0, "~", 0 ,0 ' ------> add 2 "zero bytes" to long-align
shift2 byte $22, 0, 0, 0, 0, "<_>?)!@#$%^&*(", 0, ":", 0, "+"
Paul
- PAR must be replaced with PTRA (or was it PTRB?), not PA
- the line with the if_never is never actually executed, you can just put a NOP there if you really want
- the way you replaced REV is incorrect, I think. I think the second instruction must be SHR, not ZEROX
- you might want to re-do all the I/O related stuff, as is it wont work on port B (pins 32..63)
I had PTRA at first but will change it back. I'll to the NOP you suggested and SHR instead of ZEROX
I'll have to study up on the I/O changes.
Thanks again, your expertise is truly appreciated!
(9)waitcnt changed to getct ct and add t,ct and waitx t:
' ' ' Nap ' nap rdlong t,#0 'get clkfreq napshr shr t,#18/16/13 'shr scales time fge t,#3 'ensure waitcnt won't snag getct ct add t,ct 'add cnt to time '' ----> added "getct and var ct" 'waitcnt t,#0 'wait until time elapses (nap) waitx t nap_ret retProject abandoned.
Paul
P1
entry movd :par,#_dpin 'load input parameters _dpin/_cpin/_locks/_auto mov x,par add x,#11*4 mov y,#4 :par rdlong 0,x add :par,dlsb add x,#4 djnz y,#:parThis how to do it on the P2:
entry setq #4-1 ' get 4 parameters from hub rdlong _dpin, ptra[11] ' load input parameters _dpin/_cpin/_locks/_autoFor me, the trick is to spend time looking through Chip's code, and PASM2 drivers written by others to learn these little tricks.
This is the tiny bit of code (50 bytes) I use in TAQOZ to initialize the keyboard and then to receive data from it on a smartpin.
Where PS/2 gets more complicated is in handling the scancodes, the makes and the breaks, and then generating an ASCII code for that key. I allocate a 256 byte table for the scancode conversion table and simply assign hex values $F1 to $FC for the function keys etc. Altogether including some demo code and the table, the PS/2 "driver" takes 636 bytes.
Don't give up, just get the basics functional first.
