When will the P2 Edge be available again?
Dave Hein
in Propeller 2
I am interested in purchasing a P2 Edge, but it is currently out of stock. Does anybody know when the P2 Edge will be available again?
I believe they are working on that right now.
Ken will be broadcasting todays P2 Zoom live from the manufacturing department !!
Thanks, I'll check the Parallax site tomorrow to see if I can order one.
FYI - In today's mail, a great P2 article in Nuts & Volts magazine by Jon McPhalen
Not yet.
The web-store does not have this feature yet.
Something wrong, somewhere, because I personally received 100 of those power supply adapters today.
Will check in the morning and fix this problem.
I wanted to get my order in before they sold out so I got the individual pieces. The P2 Edge and mini-board should be a perfect fit in my robot! It will be fun setting up a P2 to control 6 P1s!
The P2 Edge is somehow way smaller than I imagined:
I noticed the new PropPlug I got had rough edges. I sanded them down, but we need to start doing this in manufacturing.
Ken
It brings out 4 groups of 8 consecutive I/O pins plus the 4 3.3V lines associated with each set of 8 pins. You can't see it in the picture, but there is a Prop Plug on the back side that connects to 4 pins grouped together with GND, RESn, P63 and P2.
Here's a 3D rendition of the adapter board.
On a side note - the 80-pin Adapter mini-board needs work. Something like Dave Hein's rendition, but for 80-pins. Add in revising the pinout drawing showing the correct numbering of the double row of .100" pins (they need to be reversed)
Maybe another PCB for the RH angled 80-pin connector. the pin spacing is totally different and the RH connector does not fit into the Adapter board. I can mark up the drawings and suggest a better layout, ie. something like Dave Hein's rendition.
https://www.parallax.com/package/p2-edge-80-pin-adapter-kit-header-and-socket-pinouts/
The next phase of our work from @"Jeff Martin" after the Prop Tool 4.2 is released is to start to bring the examples into a sensible collection from GitHub, forums, PropTool and the web site so that people can get started more easily. The examples exist but they're scatterred. We'll get there, next.
@"Ken Gracey" - I better catch up - I'm only on v2.4!
