P2 clock issues
rjo__
in Propeller 2
Issue 1
If we set the system clock from Spin2 in the usual way...what actually happens?
debug shows an actual clkfreq = 297_187_500
Is the actual system clock 297_175_000 with a 12KHz jitter? or is actually a solid 297_187_500?
debug_clock1.spin2 exercises the logic a little.
'debug_clock.spin2 CON _clkfreq = 297_175_000 VAR PUB go() debug(`d `udec_(clkfreq))
Yes. It is what Rayman uses to set his NCO frequency... he wrote a nice description at rayslogic.com/Propeller2/NCO.htm
He targets the NCO frequency to be 12.375 MHz.
The issue for me was that the accuracy depends up the ratio between the system and NCO periods. At 297_175_000 you end up with something close to nice integer which can be fed back into the smart pin... producing an error frequency of about 7.2916667 kHz
but if the actual system is running at 297_187_500 the ratio is not so close to a nice integer and the error frequency goes up ton about
7.8125 kHz
The problem tends to gets worse as your intended output frequency increases.
et.al.
I don't have a scope... but I think actual behavior of the system clock is important.
Anyone?
Fortunately, most things don't seem to need precision...
Stay tuned and be ready:)
Whatever it is, it is.
Expanding on the above,
1-297175000/297187500 = 42.061ppm deviation
or one part in = 23775
P2 uses integer dividers of 6-10 bits, in the PLL, so the quantize/rounding effect of those will determine the actual PLL result.
You might be able to manually find a N/M ratio that is better than 42ppm, but 42ppm is sounding quite good.
If you really need better than 42ppm, you will need better than a simple crystal ?
If you have a high precision clock source at the P2 input, you need to choose a system frequency that the PLL divider and multiplier together can produce exactly.
You don't need a nice integer ratio for exact NCO frequencies. The ratio between system clock and NCO frequency affects the jitter, but not the error of the output frequency.
Andy
The closest possible is 20MHz * 951 / 64 = 297_187_500 Hz.
The problem gets worse the higher you go. Let's say trying to output 121.223MHz. +/- 2%.
There are a lot of ways to skin this cat... I'm just trying to get the lay of the land at this point.
Rich
If there were a system clock output, and the scope had a frequency counter included and the crystal oscillates with exactly 20 MHz +- 0 ppm.
Thank you.
Yes. 2% should be no problem, with integer ratios.
A simple x6 (PFD = 20MHz) gives 120MHz which is 1.02% error
As PFD lowers you can get more choices :
eg 20M/17 gives a solution x 103, to give = 0.038% error
Another solution is 20MHz / 33, then x 200, for a ~ 90ppm error
Lower PFD's give slightly higher jitter, so usually a design chooses the highest PFD that is 'good enough' to comfortably meet spec.
I've been meaning to try that... Might be fun with things like this...
Peter,
I was wondering if you have tried Chips new stuff with the debugger... I'm a big fan. Don't have to use serial to see results... couple of lines of code... wow. But, I think it might assume a 20Mhz crystal. Can you run any of the resent examples in PNUT 35b download?
Regards all.
Rich
It just needs 10MHz or more from a crystal or external source. It can't use RCFAST.
I think I got myself confused by putting different values for the crystal into the configuration... I got away with values close to 20MHz but problems away from that value... putting in the wrong crystal frequency was probably not a good idea:)
I think _xtalfreq is the symbol that lets you set the crystal frequency away from 20MHz. Then, _clkfreq lets you select the PLL frequency.
