555 Timer circuit question
Hello all again! This has to be super simple, but I cannot figure this out for the life of me. I have T8 LED lights in my shed that run from 12V DC and they are/were activated by a motion sensor attached to a simple 555 IC set to keep the lights on for 2 minutes once the motion sensor triggered. That part works, but since I moved the circuit to a soldered project board, the circuit doesn't discharge the capacitor when motion is sensed during the 2 minute count down to keep the lights on for another 2 minutes without turning them off. I built the circuit about 3 years ago on a basic breadboard and it was much too large and sketchy to leave it like that anymore. Maybe there was something different on the breadboard than my new smaller circuit, but I have traced everything I can from the pictures I took before taking it down.
How can I reset the capacitor charge upon trigger without resetting the output of the 555. Basically, if the output is low and trigger brought low, flip output to high and begin charging cap. If trigger is brought low at any point while capacitor is charging, leave output high, but discharge capacitor to reset time. I can post a schematic of needed. Any help is greatly appreciated
Please post the schematic, to see if we can spot anything obvious...
Are you using the same 555 Timer IC type/package or a different one between the breadboard and the PCB version?
Yes, the addition of the diode should accomplish what you want to do. You will probably need to re-adjust R2 slightly to get back to the 2 minute time delay amount that you want.
Good job.
Make R2 a combination of resistor and potentiometer in series.
In your drawing the discharge pin will try to dicharge the 12V supply with the potentiometer in bottom end position. Nogod.
I still thumb through my Radio Shack/Forest Mims "Engineers Notebooks" occasionally, and my go-to site for 555 info is at https://electronicsclub.info/555timer.htm
With 200mA output and a bulk price of 4 cents each, I still see these chips being useful for many decades to come.
https://www.ebay.com/itm/311521048962
Sadly, we did our jobs too well and the mayor of LA killed our company, and any chances of its survival. When the courts are back to normal businesses, several lawsuits will expose [even more of] the corruption inside LA city hall. Interestingly, the agency where we discovered some very serious IT problems is an agency that the mayor uses as a cudgel against citizens.
Oscillator/clock generator, timer, missing pulse detector, thermostat, level sensor, pwm, etc.. The list goes on and on.
Receiving an OBE is quite an honor. Do you know if it was that for a technical or some other accomplishment?
Using a 555 as a watchdog timer/missing pulse detector is an excellent use for many applications. I have used it for computers, microcontrollers, and old hard wired logic controllers. My first and most critical use was to protect mass spectrometers from a fore pump failure. If the mechanical fore pump failed the diffusion pump could overheat and cause damage that would cost tens of thousands of dollars to repair.
Back in 2011 I entered a 555 Contest with a Music Box player design that used a number of 555 oscillator circuits using a custom infrared LED paper tape/strip reader. I didn't win anything but I at least got an honorable mention. The following links contain a video and documentation of my project entry:
Video of the 555 MusicBox playing
Project/Circuit Documentation
Nice project, and one of my favorite tunes. One of my nieces took up piano and that was one of the first tunes she learned to play. Recently my granddaughter also took up piano and has learned Music Box Dancer as well. There is hope for some musical talent in the family.
Related and timely: https://www.servomagazine.com/magazine/article/the-biggest-and-smallest-555-youll-ever-see
I was considering a Picaxe for this purpose.
