Right Angle connector question — Parallax Forums
450-00308 product.
Is there a KiCad symbol and footprint for this item so we can build a board to put it on?
  • VonSzarvasVonSzarvas Posts: 3,631
    edited 2020-11-19 17:45
    We have a Diptrace symbol. Maybe that could be converted somehow?
    @jmg might know.
  • JonnyMacJonnyMac Posts: 9,715
    edited 2020-11-19 21:56
    Isn't that the same connector used by the Micro:bit? That maybe that connector is part of the KiCad library.
  • JonnyMac wrote: »
    Correct.
    Although maybe one gotcha... some of the more recent connectors I've seen only have half the pins populated (top side only, as that's all Micro:bit needs, as you know)
    So just to watch out; that the connector pattern has both top and bottom pins included.
    If it helps, here's the P2 socket pinout:
