Something I did....
in Propeller 1
Yes, I accidently plugged the Propeller Plug into the PROPMINI upside down or backwards. Now, I get an error message in PROPBASIC.."ERROR in DOWNLOAD". So, the question is, did I ruin the PROPMINI, the Propeller Plug, or both? Yes, I am not happy with myself...
Phone call to Parallax on Monday, for new stuff?
Thanks...DenO
Thanks...DenO
That really bites.
Thanks to all for your help...
As far as I can tell each and every piece of electronic gear that has some form of cpu and software also has some kind of quirky behaviour. My Prop development setup has a power bar that everything connects to for dealing with the quirks. Surprising how often powering down and back up fixes things.
Thanks for posting photos of your project. I always like seeing what other forum members make and your thermostat looks fantastic inside and out.
My experience tell me it was harder to reprogram the prop while using them.
I guess you destroy temporary the rs232 communication plug, and do not work as expected.
When force the rest pin, the prop stop use pin 30&31 for a moment, and the "normal" plug communication start.
Once the soft is running fine, there is no trouble to use pin 30 and 31.
