Accurate DAC Reference Data/Voltages from P2 Silicon
Tubular
in Propeller 2
Here's some accurate raw data taken of each code level 0..255 from each pin P0..31 of "Board2"
I've run out of time for now, but will come back to this for analysis down the track. I post it here in case its useful for others. My intention is to use this DAC data, captured from a calibrated multimeter, to in turn study the performance of the ADCs on each pad.
The column data is in volts. The multimeter was fixed on 10V range for the duration of these tests. For each pin there are 260 readings - two GIO readings (second is more settled/accurate), the 256 code steps of the DAC, then two VIO readings (second is again more settled/accurate).
I'll come back to measurement of the slow comparator DAC at some later time. Chip has some thoughts about how to do this, which should work.
EDIT: Updated with axis labels
EDIT2: Fixed the image resolution
EDIT3: Change "scale" to "span"
It'll be interesting to see how these vary from chip to chip. We can take some broader measurements across a batch of assembled boards
EDIT: Update spreadsheet with span labelling
The test example - I set three different DACs to exactly 1.000 / 1.500 / 2.000 volts, and read the corresponding ADC voltages within +/- one digit count (again verified by my voltmeter ) Hope this helps.
