NeoPixel Current
in Propeller 1
I am planning on using 2 NeoPixel rings with 12 NeoPixels each on a Propeller Robot Control Board (#28230) and was wondering if that is too large a current draw on two separate output pins?
One advantage NeoPixels have, is they're not powered from the I/O pin. The I/O pin just sends data to the NeoPixels to tell it which colors to display. The power to the LEDs come from the 5V power line.
In a way, NeoPixels are comparable to servos. The data line on a servo isn't powering the motor, just like the data line on NeoPixels isn't powering the LEDs.
That board should work particularly well with NeoPixels. I've had many NeoPixels which don't work will with 3.3V logic. The board you have shifts the logic up to 5V so the NeoPixels should behave well.
