Windows Serial Programming - C++ (MFC)
Hello Everyone
For nearly a decade, I have occassionally dabbled with serial programming in Windows, with my first exploit being documented in this thread: https://forums.parallax.com/discussion/133979/project-in-progress-new-serial-terminal-taking-suggestions/p1
Until recently, I had only found a couple of example programs of serial communication in MFC (Microsoft Foundation Classes). The examples that were readily available, were indeed quite complex to say the least. In an effort to simplify some of my current endeavors, I have currently been looking for simpler solutions and examples, and today I came across this web page, with a simple example: https://ontrak.net/mfc.htm
I have not really begun to toy around with it just yet, but I thought some of you may be interested, for the purpose of sending serial commands to your various robots or projects.
Can it really be this simple?
I intend to find out.
Today I write all my windows code in C#. I find it does a good job of handling the user interface and allows me to get the job done. I will say that C# is a little harder at dealing with binary data as it does not allow you to use pointers.
My last couple of projects was dealing with Bluetooth BLE and UDP data which is kind of like wireless com ports.
I have a machine which I can now control via WiFi, Bluetooth with Android app, or direct serial connection to the PC.
My goal now is to simplify my serial program and wirelessly send commands via Bluetooth from the PC with the assistance of a Bluetooth adapter.
1. Use CreateFile (yep, same API function you'd use to open a file) to open the port
2. Call GetCommTimeouts() to get current settings, make mods, and SetCommTimeouts() to make the port non-blocking
3. Call GetCommState() to get current settings, call BuildCommDCB() to create a block of port settings, then SetCommState() with the DCB you built to set comm settings like "9600,n,8,1"
All this requires about four pages of code. If you did everything perfectly this results in an open port. You are then supposed to launch a thread to monitor for input, and on 16-bit Windows and emulation with Wine if you don't do that you can't receive data, but on 32 and 64-bit Windows (NT 4.0 thru 10) you can get by with polling because the OS buffers incoming data for you. You do need to check GetOverlappedResult() before sending data to make sure the buffer is ready or outgoing data will be lost.
Here is the source code that I used:
void CTestComPortDlg::OnSend() { // variables used with the com port HANDLE m_hCom; CString m_sComPort; CString strCommand; DCB m_dcb; DWORD iBytesWritten; m_sComPort = "Com5"; m_hCom = CreateFile(m_sComPort, GENERIC_READ | GENERIC_WRITE, 0, // exclusive access NULL, // no security OPEN_EXISTING, 0, // no overlapped I/O NULL); // null template SetupComm(m_hCom, 128, 128); // set buffer sizes GetCommState(m_hCom, &m_dcb); m_dcb.BaudRate = 9600; m_dcb.ByteSize = 8; m_dcb.Parity = NOPARITY; m_dcb.StopBits = ONESTOPBIT; m_dcb.fAbortOnError = TRUE; SetCommState(m_hCom, &m_dcb); GetDlgItemText(IDC_COMMAND, strCommand); WriteFile(m_hCom, strCommand, strCommand.GetLength(), &iBytesWritten, NULL); CloseHandle(m_hCom); }
And here is a picture of the tiny little dialog app
It is almost comical
The premise of readily available code libraries does absolutely nothing for me. If you weren't coding in the 80's, I don't trust you
Mickster
Are you picking on my tiny, but bloated MFC dialog app?
Must I create a "LEAN AND MEAN" Win32 Console app?
Actually, that is a nice piece of code for a command line app, which would make it short and sweet.
My point was that to take comfort in "huge available libraries" might mean that you trust in huge inefficient code, written by others....which has long been the premise of C programming....along with "portability" which is mostly a joke
However in reality, MFC applications are naturally bloated. In a release build of that tiny application, it reduces down to a size of 112KB. Creating the same capabilities in a Win32 console app would drastically reduce the final size of the executable.
