FullDuplexSerial control codes
frank freedman
in Propeller 1
Is there a clear screen code in full duplex serial object?
Thx
Thx
In the PST (parallax serial terminal, 0 or 16 does the job)
You can find this in the Preferences of the PST.
In the Putty terminal you can use ansi control codes.
term.str(string(27)) 'Set command mode term.str(string("[2J")) 'Clear telnet screenI prefer to use putty as my terminal because you can do colors and other fancy things.
Escape codes: https://forums.parallax.com/discussion/comment/1434641/#Comment_1434641
You can even do full "graphics" with ansi and putty. (ansi art)
https://forums.parallax.com/discussion/comment/1434744/#Comment_1434744
con { pst formatting } ' Control codes for Parallax Serial Terminal HOME = 1 CRSR_XY = 2 ' next two bytes in stream are x and y positions values CRSR_LF = 3 CRSR_RT = 4 CRSR_UP = 5 CRSR_DN = 6 BELL = 7 BKSP = 8 TAB = 9 LF = 10 CLR_EOL = 11 ' clear to end of line CLR_DN = 12 ' clear everything after cursor F_FEED = 12 CR = 13 CRSR_X = 14 ' next byte in stream is x position value CRSR_Y = 15 ' next byte in stream is y position value CLS = 16Thank you all for the fast replies.
@JonnyMac, your con listing helped solve it. I had tried using $10 and that did not really clear it (possibly the PUTTY setting?), but using $C, the form feed took care of the issue.
@"Clock Loop", Guess I make some less than optimal assumptions on the PUTTY setup. Had not looked for a PUTTY setup screen such as you have posted. Gonna revisit that one now. Thx
Close but I need to dig more on escape sequences.
Parallax forums, best peeps, best ideas and help when needed!!
P.S. I've always wondered why PST pays no regard to these terminal standards and seems to be setup to emulate serial LCD codes for compatibility. What is needed in PST is an "LCD emulation mode" button just for that.
I know the parallax serial terminal ascii codes do not work the same in putty, I don't use them.
I strictly stick to ansi escape codes with putty, putty doesn't have a setup screen like the pst does(thats the image i posted from parallax serial terminal)
The way they work is you first must SET COMMAND MODE before every command.
And you must do it again if you issue another ansi command.
And again if you issue yet another command.
The sequence is, set command mode, then set the command, then send the text.
https://forums.parallax.com/discussion/comment/1453119/#Comment_1453119
Here are some escape sequences:
'--------------SOME ANSI COMMAND CODE INFO--------- 'term.str(string(27)) 'Set command mode 'term.str(string("[2J")) 'clear screen 'term.str(string(27)) 'Set command mode 'term.str(string("[0m")) 'Turn off character attributes 'term.str(string(27)) 'Set command mode 'term.str(string("[1m")) 'Turn bold mode on 'term.str(string(27)) 'Set command mode 'term.str(string("[2m")) 'Turn low intensity mode on 'term.str(string(27)) 'Set command mode 'term.str(string("[4m")) 'Turn underline mode on 'term.str(string(27)) 'Set command mode 'term.str(string("[5m")) 'Turn blinking mode on 'term.str(string(27)) 'Set command mode 'term.str(string("[7m")) 'Turn reverse video on 'term.str(string(27)) 'Set command mode 'term.str(string("[8m")) 'Turn invisible text mode on 'term.str(string(27)) 'Set command mode 'term.str(string("#3")) 'Double-height letters, top half 'term.str(string(27)) 'Set command mode 'term.str(string("#4")) 'Double-height letters, bottom half 'term.str(string(27)) 'Set command mode 'term.str(string("#5")) 'Single width, single height letters 'term.str(string(27)) 'Set command mode 'term.str(string("#6")) 'Double width, single height letters { Esc#3 Double-height letters, top half DECDHL Esc#4 Double-height letters, bottom half DECDHL Esc#5 Single width, single height letters DECSWL Esc#6 Double width, single height letters DECDWL }For putty and ansi escape codes, heres how I do it in an accelerometer debug output to the putty terminal.
https://forums.parallax.com/discussion/comment/1507383/#Comment_1507383
Repeat 'The main repeat loop. Cog#2 ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[2J")) 'Clear putty telnet screen. ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[2;3f")) 'Set Position in putty. ser.str(string("Put your text here.")) 'Send text to the putty terminal. ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[1;1f")) 'Set Position in putty to put cursor at 0 ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[4;3f")) 'Set Position in putty If ReplyStatus == 1 ser.str(string("Good reply.")) 'If last reply was good, put it back up on putty which was cleared. ReplyStatus := 0 ' Else ser.str(string(" No reply.")) 'If last reply was none, put it back up on putty which was cleared. ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[5;3f")) 'Set Position in putty ser.str(string("Tilt X that the Prop sent: ")) ' ser.dec(long[@TiltX][0]) ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[6;3f")) 'Set Position in putty ser.str(string("Tilt Y that the Prop sent: ")) ' ser.dec(long[@TiltY][0]) ser.str(string(27)) 'Set ansi command mode in putty. ser.str(string("[1;1f")) 'Set Position in putty to put cursor at 0I removed all the code except the ansi command codes and sequences.
https://hackaday.io/project/162734-a-trillion-year-clock
'' ================================================================================================= ' File...... TrillionYearClock.spin ' Purpose... Trillion Year Clock Telnet RGB Led Timer Eeprom Demo ' Author.... Clock Loop @ parallax forums ' Started... 2016... ' Updated... 2018... See you in a trillion years. '' ================================================================================================= Pub PaintScreen term.str(string(27)) 'Set command mode term.str(string("[2J")) 'clear screen term.str(string(27)) 'Set command mode term.str(string("[2;3f")) 'position term.str(string(27)) 'Set command mode term.str(string("[35m")) 'Purple color text term.str(string(27)) 'Set command mode term.str(string("[1m")) 'Turn bold mode on 'term.str(string(27)) 'Set command mode 'term.str(string("[4m")) 'Turn underline mode on term.str(string(27)) 'Set command mode term.str(string("#3")) 'Double-height letters, top half term.str(string("Trillion Year Clock")) term.str(string(27)) 'Set command mode term.str(string("[3;3f")) 'position term.str(string(27)) 'Set command mode term.str(string("#4")) 'Double-height letters, bottom half term.str(string("Trillion Year Clock")) 'term.str(string(27)) 'Set command mode 'term.str(string("[1;1f")) 'Set Position 'term.str(string(27)) 'Set command mode 'term.str(string("[0m")) 'Turn off character attributes term.str(string(27)) 'Set command mode term.str(string("[2;25f")) 'position 'term.str(string(27)) 'Set command mode 'term.str(string("[1m")) 'Turn bold mode on ' term.str(string(27)) 'Set command mode term.str(string("[33m")) 'Yellow color text ' term.str(string(27)) 'Set command mode term.str(string("#3")) 'Double-height letters, top half term.str(string("Ticker : ")) If Secs < 10 term.dec(0) term.dec(Secs) term.str(string(27)) 'Set command mode term.str(string("[2;39f")) 'Set Position term.dec(TenthTimer) term.str(string(" ")) term.str(string(27)) 'Set command mode term.str(string("[3;25f")) 'position term.str(string(27)) 'Set command mode term.str(string("#4")) 'Double-height letters, bottom half term.str(string("Ticker : ")) If Secs < 10 term.dec(0) term.dec(Secs) term.str(string(27)) 'Set command mode term.str(string("[3;39f")) 'Set Position term.dec(TenthTimer) term.str(string(" ")) term.str(string(27)) 'Set command mode term.str(string("[0m")) 'Turn off character attributes term.str(string(27)) 'Set command mode term.str(string("[1;1f")) 'Set Position '---------------------------------------------- 'term.str(string(27)) 'Set command mode 'term.str(string("[2J")) 'clear screen 'term.str(string(27)) 'Set command mode 'term.str(string("[0m")) 'Turn off character attributes 'term.str(string("[1m")) 'Turn bold mode on 'term.str(string("[2m")) 'Turn low intensity mode on 'term.str(string("[4m")) 'Turn underline mode on 'term.str(string("[5m")) 'Turn blinking mode on 'term.str(string("[7m")) 'Turn reverse video on 'term.str(string("[8m")) 'Turn invisible text mode on 'term.str(string("#3")) 'Double-height letters, top half { Esc#3 Double-height letters, top half DECDHL Esc#4 Double-height letters, bottom half DECDHL Esc#5 Single width, single height letters DECSWL Esc#6 Double width, single height letters DECDWL } 'term.str(string(27))', HOME, LF, LF)) 'term.str(string(27)) 'term.str(string(27)) 'Set command mode 'term.str(string("[1;1f")) 'Set Position 'term.str(string(27)) 'Set command mode 'term.str(string("[4;5f")) 'Set Position 'term.str(string(27)) 'Set command mode 'term.str(string("[30m")) 'Black color text 'term.str(string("[31m")) 'Red color text 'term.str(string("[32m")) 'Lime color text 'term.str(string("[33m")) 'Yellow color text 'term.str(string("[34m")) 'Blue color text 'term.str(string("[35m")) 'Purple color text 'term.str(string("[36m")) 'SkyBlue color text 'term.str(string("[37m")) 'White color text term.str(string(27)) 'Set command mode term.str(string("[5;5f")) 'Set Position ' term.str(string(27)) 'Set command mode term.str(string("[32m")) 'Lime color text term.str(string("RunTime : ")) term.dec(uTrillionYears) term.str(string(":TrillionYears ")) term.dec(uBillionYears) term.str(string(":BillionYears ")) term.dec(uMillionYears) term.str(string(":MillionYears ")) term.dec(uMillennium) term.str(string(":Millennium ")) term.str(string(27)) 'Set command mode term.str(string("[6;16f")) 'Set Position term.dec(uCentury) term.str(string(":Century ")) term.dec(uDecade) term.str(string(":Decade ")) term.dec(uYears) term.str(string(":Years ")) term.dec(uDayz) term.str(string(":Days ")) term.dec(uHour) term.str(string(":Hours ")) term.dec(uMnit) term.str(string(":Min ")) term.str(string(27)) 'Set command mode term.str(string("[1;1f")) 'Set Position term.str(string(27)) 'Set command mode term.str(string("[8;5f")) 'Set Position term.str(string(27)) 'Set command mode term.str(string("[31m")) 'Red color text term.str(string("UpTime : ")) term.dec(TrillionYears) term.str(string(":TrillionYears ")) term.dec(BillionYears) term.str(string(":BillionYears ")) term.dec(MillionYears) term.str(string(":MillionYears ")) term.dec(Millennium) term.str(string(":Millennium ")) term.str(string(27)) 'Set command mode term.str(string("[9;16f")) 'Set Position term.dec(Century) term.str(string(":Century ")) term.dec(Decade) term.str(string(":Decade ")) term.dec(Years) term.str(string(":Years ")) term.dec(Dayz) term.str(string(":Days ")) term.dec(Hour) term.str(string(":Hours ")) term.dec(Mnit) term.str(string(":Min ")) Pub DotOff term.str(string(27)) 'Set command mode term.str(string("[2;38f")) 'Set Position ' term.str(string(27)) 'Set command mode term.str(string("[1m")) 'Turn bold mode on term.str(string(27)) 'Set command mode term.str(string("[35m")) 'Purple color text term.str(string(27)) 'Set command mode term.str(string("#3")) 'Double-height letters, top half term.str(string(".")) term.str(string(27)) 'Set command mode term.str(string("[3;38f")) 'Set Position term.str(string(27)) 'Set command mode term.str(string("#4")) 'Double-height letters, bottom half term.str(string(".")) term.str(string(27)) 'Set command mode term.str(string("[1;1f")) 'Set Position Pub DotOn term.str(string(27)) 'Set command mode term.str(string("[2;38f")) 'Set Position ' term.str(string(27)) 'Set command mode term.str(string("[1m")) 'Turn bold mode on term.str(string(27)) 'Set command mode term.str(string("[37m")) 'White color text term.str(string(27)) 'Set command mode term.str(string("#3")) 'Double-height letters, top half term.str(string(".")) term.str(string(27)) 'Set command mode term.str(string("[3;38f")) 'Set Position term.str(string(27)) 'Set command mode term.str(string("#4")) 'Double-height letters, bottom half term.str(string(".")) term.str(string(27)) 'Set command mode term.str(string("[1;1f")) 'Set Position Dat {{ Terms of Use: MIT License }}Nice, this will do very nicely for what I am trying to do. Thank you. If I get it right, I can place the labels on the screen where I want and then paste the values as needed whenever on an ANSI compliant terminal?
term.str(string(27)) 'Set command mode term.str(string("[2J")) 'clear screen term.str(string(27)) 'Set command mode term.str(string("[2;3f")) 'positionbecomes
Thats exactly it, with ansi, you tell it what position you want your text.
There are other command codes, but I do not know exactly which ones will work in putty.
https://en.wikipedia.org/wiki/ANSI_escape_code#Escape_sequences
All the ones in my example code above do work, i know that (so the text attributes and colors, cursor positioning etc)
For some, needing to set the exact position of all text is annoying, but personally I love it, even though it gets kinda repetitive.
Clear the screen at the first part of the loop.
You don't HAVE to do this, but it prevents serial data output corruption that sometimes happens.
Overwriting specific positions is possible but I found that when you don't repaint it all, things start to deteriorate.
Repeat term.str(string(27)) 'Set command mode term.str(string("[2J")) 'clear screenSet any special text features, like color or bold, etc.
term.str(string(27)) 'Set command mode term.str(string("[31m")) 'Red color text term.str(string(27)) 'Set command mode term.str(string("[1m")) 'Turn bold mode onSet your position, this one is 3 lines down, 5 spaces in. Set the cursor position right before you output your text
or you will have annoying blinking cursors all over the place in your terminal.
term.str(string(27)) 'Set command mode term.str(string("[3;5f")) 'set positionOutput the text and values
term.str(string("This is your variable: ")) term.dec(decimaldatavariable)Always set the cursor position back to 1,1 before you do any thing else in your code,
term.str(string(27)) 'Set ansi command mode in putty. term.str(string("[1;1f")) 'Set Position in putty to put cursor at 1,1FYI, I THINK TEXT ATTRIBUTES STAY ON, until you turn them off or change the attributes.
There is a command to turn off all attributes...
term.str(string(27)) 'Set command mode term.str(string("[0m")) 'Turn off character attributesOh right, I suppose that does reduce code space and timing...
My brain forgets things faster than a cat does, so I end up writing everything out, slow, clunky, and like a moron.
That way I can read it 2 years from now and not scratch my head wondering wtf, and how did I even figure that out...
