How do I get DEBUG to work for SPIN2?
JonTitus
in Propeller 2
I have an P2EVAL board and run the P2 at 150 MHz. I use PNut (v34s) on a Win-10 PC to write and run SPIN2 programs. So far, programs compile and run. The Spin2 Language Documentation explains...
Again from the SPIN2 documentation:
Again nothing happens. I want to "watch" a 32-bit value as a program executes and have hit a brick wall with the simplest of examples. How do I get DEBUG to operate (properly)? Thanks. --Jon
That does nothing on my computer. I have tried to run the simple example below from the SPIN2 documentation, but see nothing. I press and hold CRTL and then press and release F10. I do get an error message for the debug line, though:Debugging is initiated by adding the Ctrl key to the usual F10 to 'run' or F11 to 'program'.
Expected an instruction or variable.
CON
_clkfreq = 150_000_000
PUB go() | i
repeat i from 0 to 9
debug(udec(i))
This compiles your application with all the DEBUG statements, adds the debugger to the download, and then brings up the DEBUG Output window which begins receiving messages at the start of your application.
https://drive.google.com/file/d/1ZVc9mplxXAkQ2Occ1BvgfCQ3g9CzxdF-/view
